4 HD DVR's, how to hook up? | SatelliteGuys.US
Canuck Cable Guy
3
I have a friend who is looking to install 4 dual tuner HD DVR's
He has the dish already, but there is only 4 ports from the built in LNB/multiswitch
Would he need another dish, or is there a multiswitch that can be installed using 4 lines from the LNB/multiswitch, into a second switch, so the 4 dual tuners can all have feeds?
Or can you split the lines (like DPP with Dishnet?)
Or does he just need another dish?
TIA for your help
Cheers
DVR Pauses and glitches
Switched receivers, now no signal...
