Need input from the masses. What Satellites should be dropped or added to the 4D Map Master Program. 4D Map Master... The ONLY way to map the 4DTV! Your input will be used to help what we will have for an end product when it's rolled out.
These stock tiles and 881 channels aren't worth a crap!
B6 W2 'W3 'T4 'G7 T6 G3
T5 'G6 'W4 K1 'W1 'X4 E2
A2 M1 M5 'G0 X0 'G5 G9
T7 'C3 'G1 'C4 C1
I propose the following satellites (list attached, use OpenOffice or Word to view)
let me know what you think...View attachment 62567
BTW: I had to upload as .doc format since satguys don't accept *.odt files.
I would hate to see any satellite tile removed. They are useful for using the 4DTV for FTA as a positioner/polarity/skew controller, regardless of their names/IDs.
Seems to me that was one of the original reasons (not to loose tiles) for starting the project. Now you want to remove tiles?
The "possibility" of not allowing the user to change the maps is also beginning to sound like Motorola/GI all over again. I hope I am misunderstanding.
DRCars
Limited time offer
