4dtv question | SatelliteGuys.US
4dtv question
satellitekid
13
hi all
i have a question motorola dsr 922 4dtv receiver.
can this receiver receive FTA DVB CHANNELS,OR NOT
can i get fta channels with this receiver,c band and ku band
or DC II FTA CHANNELS.
THANKS
The 4dtv receivers can't pick up DVB, you'll need a separate receiver for those channels. You will be able to pick up some NTSC channels that are FTA, and if the 4dtv has been authorized you can pick up a few DC II channels. I'm not sure if it has to currently be authorized or not on the free DC II channels.
A good source for what is available can be found on the lyngsat web site.
satellitekid said:
hi all
THANKS
The 4DTV receivers need to be authorized by some service provider before they will do much of anything. That's usually a freebe. There are still a lot of analog C-band signals out there, although most of the Ku stuff is digital (MPEG, Digicipher, etc.), but there are notable exceptions.
I've noticed that some of the (what I understood to be subscription) 4DTV services come and go (a lot like analog stuff does/used to), but there is a lot of it that is free. I suppose someone mistypes an authorization code once in awhile.
As some others have mentioned, you will need an MPEG receiver, and a couple of 1gHz splitters, an DiSEqC switch, (and maybe some sort of relay switching to allow the MPEG receiver to control the polarizer), to receive those signals. Low-end MPEG receivers aren't all that expensive either.
I hope this is helpful.
(This is the edit) Oh boy. Now I'm confused. I was just looking at Skyvision and read this:
"Digital DigiCipher® II Programming. The 4DTV receiver comes with full MPEG-2 decompression capability built-in, which enables you to receive more programming per satellite in both scrambled, and "in the clear" digital formats."
Sounds like Motorolaganda, but then, what do I know.
