4dtv time off this morning | SatelliteGuys.US
iammike
953
Roanoke,VA
While I was getting ready for work this morning I noticed that the clock on my 922 was off by about 7 or 8 minutes. At least in comparison to the clock on CNBC. I'm assuming that everyone's time is off, although there was a brief power outage Saturday night at my place. Anybody else seeing the same thing?
Not here
Nope...mine is still on...probably will catch up next guide hit you get!
Jeff
Jeff
Hmmm? I had to cut my box on this morning, so it should have got the guide last night. But I didn't check it. I just look at news channels while getting ready for work in the morning. I'll play with it some tonight.
Actually, I've got a better theory, I think its a conspiracy between Motorola and my employer trying to trick me into getting to work on time. :)
Hey Jeff,
Your suggestion in the IPG thread worked like a champ for fixing my clock problem. I switched to G1-3 held down the guide button for about 30 seconds and the clock was reset to the correct time. Interesting thing was I already had guide info prior to doing this.
Thanks for the tip! If DFergie is reading this, it might be good FAQ info if it's not there already.
Mike
iammike said:
Hey Jeff,
Mike
This post ? If so reply here, I am about to shut down Pc to go to work... so will add in the morning... Thanks :)
That's the one. Changing channels to G1-3 and then holding down the guide button for 30 seconds to force a guide download and/or reset the receiver's clock seemed like good FAQ info.
Thanks,
Mike
Glad it worked Mike
Thanks,
Mike
Glad it worked for you Mike... It is a handy dandy "fix" for a lot that goes on with the clock and IPG!!:)
Regards
jeff
Ex-C-Band Member
can one use small dish lnbf on 8.5' dish
