4dtv ??? | SatelliteGuys.US
4dtv ???
docj2005
294
st louis park mn
is there any 4dtv on ku band or is it all on cband...
i would love to test out my dsr922 a little more before it sells...
its up for sale right now in the classifieds
There is some on Galaxy 4. Known as X4 on a 4DTV. If you have not downloaded recent maps from a C band sat, it might not work though.
i have been trying g4 aka g16 and get noda
i will guess this unit does work and hope someone else can use it
i dont have cband to try it out there
oh well
Its up for sale check out the ad in the classifieds
Make sure you are using the X4 tile unless you were trying with a C-band dish.
Double check that it's setup for an LNBF and has the L.O. set right.
Even after all of that, you still may not see any channels, but you should be able to get a DC lock on X4-4, X4-5, X4-6, X4-7, X4-9 etc. Basicly any of the TPs that are carrying DCII on Galaxy 16. If you have the maps you should be able to tune the actual channels.
One other thing, for a Ku LNBF, you'll need to mark the checkbox for it being 90 degrees rotated. Every Ku LNBF seems to have this issue with 4DTV boxes. Also needs to be standard Ku, not universal.
Back to the Basics - Please Help!
Line of Sight
