5/26/2010 2:27pm - Uplink Activity Report - 20 changes | SatelliteGuys.US
D
DigiDish Uplink Report
Guest
SatelliteGuys.US DishNetwork Uplink Activity Report - 5/26/2010 2:27pm - 20 changes
Uplink Comparison Range: 05/26/2010 09:06A - 05/26/2010 02:26P
Channel Additions:
7882(29) - WMUM [MPEG4 SD] added to EchoStar8 77W TP 16 ConUS beam (NA)(Cochran, GA-PBS)
7881(64) - WGNM [MPEG4 SD] added to EchoStar8 77W TP 16 ConUS beam (A) (H)(Macon, GA-IND)
7883(58) - WPGA [MPEG4 SD] added to EchoStar8 77W TP 16 ConUS beam (NA)(Perry, GA-ABC)
6525(33) - KEMY [MPEG2 SD] added to EchoStar10 110W TP 20 Spotbeam 43 (NA)
9393 - 3ABN [MPEG2 SD] added to Ciel-2 129W TP 21 ConUS beam (A)
9393 - 3ABN [MPEG2 SD] added to EchoStar6 61.5W TP 04 ConUS beam (A)
Channel Removals:
5991 - TEMP (NA) [MPEG AUDIO] removed from EchoStar9 121W TP 16 ConUS beam
Channel Moves:
9650 - HDBTV [MPEG4 HD] moved from EchoStar9 121W TP 17 ConUS beam to EchoStar9 121W TP 16 ConUS beam (A)
Channel Package Flag Changes:
5160(9) - KTEN3 [MPEG4 HD] - Ciel-2 129W TP 16 Spotbeam 36 changed to Available (H)(Ada, OK-N/A)
5160(9) - KTEN3 [MPEG4 HD] - Echostar12 61.5W TP 01 Spotbeam 16 changed to Available (H)(Ada, OK-N/A)
7520(9) - KTEN3 [MPEG2 SD] - EchoStar10 110W TP 20 Spotbeam 21 changed to Available (H)(Ada, OK-N/A)
361 - MAVTV [MPEG4 HD] - Ciel-2 129W TP 19 ConUS beam changed package flags (A)
361 - MAVTV [MPEG4 HD] - EchoStar3 61.5W TP 20 ConUS beam changed package flags (A)
596 - GLOBO [MPEG2 SD] - EchoStar3 61.5W TP 08 ConUS beam changed package flags (A)
653 - AFR24 [MPEG2 SD] - Anik F3 118.7W TP 25 ConUS beam changed to Available (H)
667 - AFRMU [MPEG2 SD] - Anik F3 118.7W TP 14 ConUS beam changed to Available (H)
751 - AFROM [MPEG2 SD] - Anik F3 118.7W TP 02 ConUS beam changed package flags (A)
801 - KAIRA [MPEG2 SD] - Anik F3 118.7W TP 03 ConUS beam changed package flags (A)
814 - GLOBO [MPEG2 SD] - Anik F3 118.7W TP 30 ConUS beam changed package flags (A)
9629 - BTV [SD TV] - EchoStar9 121W TP 13 ConUS beam changed to Available
Channels in the system: 7157
(A) = Available to subscribers
(NA) = Not Available
(H) = Hidden from non-subscribers
The Format and Layout of the SatelliteGuys Uplink Report is © Copyright 2010 SatelliteGuys.US and may not be republished without written permission from SatelliteGuys.US.
The SatelliteGuys Uplink Report is powered by Digiblur Technologies! - DigiDish v10.05.24
© 2010 - All Rights Reserved - SatelliteGuys Incorporated
yep looks like it was added on 5/9
On May 9, 2010, the station converted its third digital subchannel from a doppler radar image to a channel that operates as the area's ABC affiliate which is known on-air as ABC Texoma.
whats weird is its broadcasting in 720p 4:3??
Maddening. I wonder what for. Not like it was already on an easily remembered number. They should put it down in the range with the rest of the religious broadcasters.
Channel Additions:
Great... putting the Macon, GA, locals on 77W. HD versions already uplinked at 77W.
Already have a 722K, so I guess it's time to ditch the 510, get a 211 and 1000.4.
So just swapped 129 for 61.5 ran check switch and 9393 worked @ 129, then swapped back to 61.5 and error #5. conclusion 9393 @ 61.5 not setup correctly by uplink center folks at dish.
D
5/27/2010 9:07pm - Uplink Activity Report - 1 change
D
5/31/2010 11:05am - Uplink Activity Report - 8 changes
