5/31/2012 2:17am - Uplink Activity Report - 25 changes | SatelliteGuys.US
D
DigiDish Uplink Report
Guest
SatelliteGuys.US DishNetwork Uplink Activity Report - 5/31/2012 2:17am - 25 changes
Uplink Comparison Range: 05/31/2012 02:01A - 05/31/2012 02:16A
Channel Removals:
5837 - TST1 (NA) [MPEG2 SD] removed from Anik F3 118.7W TP 31 ConUS beam
Channel Moves:
5273 - WTVW [MPEG4 HD] moved from EchoStar8 77W TP 14 ConUS beam to EchoStar8 77W TP 01 ConUS beam (Mkt:Evansville, IN-Evansville, IN-FOX) (A) (H)
5150 - WTVQ [MPEG4 HD] moved from EchoStar8 77W TP 14 ConUS beam to EchoStar8 77W TP 01 ConUS beam (Mkt:Lexington, KY-Lexington, KY-ABC) (A) (H)
5151 - WKYT [MPEG4 HD] moved from EchoStar8 77W TP 14 ConUS beam to EchoStar8 77W TP 01 ConUS beam (Mkt:Lexington, KY-Lexington, KY-CBS) (A) (H)
5152 - WLEX [MPEG4 HD] moved from EchoStar8 77W TP 14 ConUS beam to EchoStar8 77W TP 01 ConUS beam (Mkt:Lexington, KY-Lexington, KY-NBC) (A) (H)
5153 - WDKY [MPEG4 HD] moved from EchoStar8 77W TP 14 ConUS beam to EchoStar8 77W TP 01 ConUS beam (Mkt:Lexington, KY-Danville, KY-FOX) (A) (H)
9209 - WKYT2 [MPEG4 SD] moved from EchoStar8 77W TP 14 ConUS beam to EchoStar8 77W TP 01 ConUS beam (Mkt:Lexington, KY-Lexington, KY-CBS) (A) (H)
9211 - WKLE [MPEG4 SD] moved from EchoStar8 77W TP 14 ConUS beam to EchoStar8 77W TP 01 ConUS beam (Mkt:Lexington, KY-Lexington, KY-PBS) (A) (H)
9212 - WLJC [MPEG4 SD] moved from EchoStar8 77W TP 14 ConUS beam to EchoStar8 77W TP 01 ConUS beam (Mkt:Lexington, KY-Beattyville, KY-REL) (A) (H)
5200 - KSPR [MPEG4 HD] moved from EchoStar8 77W TP 10 ConUS beam to EchoStar8 77W TP 32 ConUS beam (Mkt:Springfield, MO-Springfield, MO-ABC) (A) (H)
5201 - KOLR [MPEG4 HD] moved from EchoStar8 77W TP 10 ConUS beam to EchoStar8 77W TP 32 ConUS beam (Mkt:Springfield, MO-Springfield, MO-CBS) (A) (H)
5202 - KYTV [MPEG4 HD] moved from EchoStar8 77W TP 10 ConUS beam to EchoStar8 77W TP 32 ConUS beam (Mkt:Springfield, MO-Springfield, MO-NBC) (A) (H)
5203 - KRBK [MPEG4 HD] moved from EchoStar8 77W TP 10 ConUS beam to EchoStar8 77W TP 32 ConUS beam (Mkt:Springfield, MO-Osage Beach, MO-N/A) (A) (H)
5204 - KOZL [MPEG4 HD] moved from EchoStar8 77W TP 10 ConUS beam to EchoStar8 77W TP 32 ConUS beam (Mkt:Springfield, MO) (A) (H)
7225 - KCZ [MPEG4 SD] moved from EchoStar8 77W TP 10 ConUS beam to EchoStar8 77W TP 32 ConUS beam (Mkt:Springfield, MO-Springfield, MO-CW) (A) (H)
7226 - KOZK [MPEG4 SD] moved from EchoStar8 77W TP 10 ConUS beam to EchoStar8 77W TP 32 ConUS beam (Mkt:Springfield, MO-Springfield, MO-PBS) (A) (H)
407 - FSC+ [MPEG2 SD] moved from Echostar15 61.5W TP 21 ConUS beam to EchoStar15 61.5W TP 14 ConUS beam (Fox Soccer Plus) (A)
4776 - FSC+ [MPEG2 SD] moved from Echostar15 61.5W TP 21 ConUS beam to EchoStar15 61.5W TP 14 ConUS beam (Fox Soccer Plus) (A) (H)
6808 - UP9 [MPEG2 SD] moved from EchoStar8 77W TP 32 ConUS beam to EchoStar8 77W TP 10 ConUS beam (Virtual Channel) (NA)
6842 - UP8 [MPEG4 HD] moved from EchoStar8 77W TP 01 ConUS beam to EchoStar8 77W TP 14 ConUS beam (Virtual Channel) (NA)
9621 - BTV [SD TV] moved from Echostar15 61.5W TP 21 ConUS beam to EchoStar15 61.5W TP 14 ConUS beam (Business TV) (A)
9622 - BTV [SD TV] moved from Echostar15 61.5W TP 21 ConUS beam to EchoStar15 61.5W TP 14 ConUS beam (Business TV) (A)
9833 - ANTRA [MPEG AUDIO] moved from Anik F3 118.7W TP 20 ConUS beam to Anik F3 118.7W TP 31 ConUS beam (ANT1 97.2 FM) (A) (H)
9837 - RYTHM [MPEG AUDIO] moved from Anik F3 118.7W TP 20 ConUS beam to Anik F3 118.7W TP 29 ConUS beam (Rythmos Radio 94.9) (A) (H)
Transponder Changes:
Echostar15 61.5W TP 21 ConUS beam 20000 QPSK 7/8 removed
Channels in the system: 8450
(A) = Available to subscribers
(NA) = Not Available
(H) = Hidden from non-subscribers
(FP) = Free Preview
The Format and Layout of the SatelliteGuys Uplink Report is © Copyright 2012 SatelliteGuys.US and may not be republished without written permission from SatelliteGuys.US.
The SatelliteGuys Uplink Report is powered by Digiblur Technologies! - DigiDish v12.04.10
© 2012 - All Rights Reserved - SatelliteGuys Incorporated
There must be a problem with 77W TP 14. When I check it on my 722k, it drops audio and signal strength on periodically.
77W TP 01 apparently much more stable as I did not see any drop in audio or signal strength.
D
5/30/2012 1:01pm - Uplink Activity Report - 32 changes
D
6/1/2012 4:02pm - Uplink Activity Report - 2 changes
