Guys, any advantage or need for a 5 lnb if D* currently does not offer local HD in my area?
Currently, no. However, if you can get a free install with upgrade of other equipment, you might consider it. I get higher signal levels than from my old 3LNB dish, so you might consider it for this reason. Otherwise, you could just wait.
About Jan. 2007 for a guess.Can anyone tell me when I can get a slim line in CT. My dish is on a pole on my roof peak
How about HD RSN's in MPEG4? Are those up and running? Someone might live in an area that does not have HD LIL, but does have HD RSNs.
No. You can't use your existing switch for HD - you need to run all four lines from the dish, one to each tuner (i.e. two to any DVR). If you need to go over four lines run all four from the dish to a WB68 multiswitch (4x8, comaptible with the new satellites) and then connect your tuners to the 4x8.
Limited time offer
