5 LNB Re-install......Help!! | SatelliteGuys.US
squirrelchaser
6
In the next week or so, I'm going to have my roof replaced which will force me to take my dish down.
What's the best way to go about having it re-installed by Directv? Cost is definitely a factor for me. Would it help if I purchased the protection plan?
What ever you do you are probably too late in scheduling it now. You want it reinstalled as soon as the roofers finish but you will probably need a couple weeks advanced scheduling.
Just to add, the Protection Plan does not cover any actions by you that cause your problem (such as removing the dish from the roof). Your best bet would be to call D* and see if you can schedule a tech to come out and relocate your dish once the roof is done.
Bad Direct Tech Experience
How much would you pay?
