5 Receivers On Dishpro Quad Lnb | SatelliteGuys.US
meis1960
I currently have 3 receivers on a dishpro 500 quad. I just purchases a 522 and want to keep the other 3 receivers. I assume that I can only add 1 receiver and not the 522 since it has 2 tuners. How can I add the 522 without elminating the other 3 with the last hookup?
You can use a DP34 switch and run 6 receivers. Run two cable runs (119,110) to the DP34 from the DP Quad to feed 4 receivers. You'll have two extra ports on the Quad to feed 2 more receivers. Make sure you feed the 522 from the same source, 2 lines from the DP34 or two lines from the DP Quad.
TiVo
Dish Expands Hurricane Channel
