510DVR Favorites Problem | SatelliteGuys.US
Fatz
Hi all,
I have a Dish510 Receiver that has a problem saving favorites. If i edit a list and save changes when I go back into that list it's title is no longer "list1" is some garbled text and if I exit and try to activate the list with the guide the receiver reboots. Everything else works fine, locks, DVR recordings etc. this is the only problem I have. I believe the software is at version P304 if that helps.
Any workarounds or guidance would be appreciated.
I have a 510 with the P304 release and do not have that problem. Have you tried to unplug it and take the card out for 10 minutes then bring it back up again.
What if the new HD channels are really still MPEG2 ?
Should Dish change to 1280 x 720?
