Anyone found a way to tame the 510s?
These units have to be manually turned off between 2 and 4AM local time to download "reset" data from a satelite.
If this isn't done, recordings have long gaps, aren't executed (even though the record red lite stays on), recorded events disappear, playback freezes, processing commands from the remote sloooooows way down, error messages while watching a broadcast, etc.
Rebooting temporarily restores functioning.
510s cannot be programmed to shut off after recording.
510s cannot down load reset data while recording.
510s cannot download reset data while the unit is on.
Rebooting does not download reset data.
No way to force a reset data down load.
No way to bypass the need for multiple, weekly data resets.
Dish suggests buying a dual receiver to solve the "software" problem. They claim the reset data is on a second satelite, and the dual receiver units can down load the reset data while the unit is on, even if recording. Of course, the monthly fee increases for a dual receiver (only $120 additional per year).
They won't allow me to trade the malfunctioning 510 towards a unit without these problems.
Of course, I can't send a dual receiver back if it suffers from similar problems; no refund on the install charges for running a second feed line from the dish antenna/amplifier.
My fourth 510 arrived yesterday. 1st one had this problem, but died after less than a year's usage; replacement 1 same problems, replacement 2 same problems, replacement 3 still in it's box.
I'm tired of fighting with these units to get them to function reliably. A $600 outlay coupled with an addition $120 annual fee doesn't seem like a resonable solution to the 510 software problem.
Thanks, Bob
Thanks, Bob
