52.0 Remote learning question | SatelliteGuys.US
LASooner
462
22
I have an older TV I want to control with my 52.0, It picked up the Volume and Mute buttons fine, but I can't seem to program the TV power button on the remote
this one
Whenever I press the other buttons during remote training, the lit TV indicator blinks, then I hold down the remote button on my TV remote and it blinks again, letting me know it took the programming. But when I press the TV power button, nothing happens. It's almost as if you can't program that button.currently I programmed my mute button to function as the TV power toggle, but that is not ideal as my wife likes to use the mute button.
My TV is a Norcent LT3250 which is listed in the programmable list, but I tried using the code and selecting my TV from Dish's built in list but it didn't work at all. It lists the TV but none of the funtions work.
Anyone else have luck or a work around for this?
If its like the 40.0 remote you do not program the TV power button, you have to program the POWER button while in TV mode.
Hopper3 & Dish Remote 40.0 Cannot get TV or AUX coded
VIP 211 and external hard drive problem
