6.0 tv2 remote question | SatelliteGuys.US
Jeff lost in cable
55
Dish replaced my DVR with a 722 yesterday. I had a 6.0 remote on another tv2 which he didn't check.
The 6.0 remote will not work any more. The new remotes are 6.3. Anyone knows how to fix this?
you remote address don't match any more to your receiver. go the menu 6-1-3 grab 6.3 remote press and hold SAT until all lights on then pick a number between 1-15 press pound(#) and then record that should fix it
It sure did work! You all are great.
Jeff
D* now has NESN HD, FSN-NY HD and MSG-HD
Question: 722 or 622?
