6/08/2016 13:58 - Uplink Report - 66 Changes | SatelliteGuys.US
Uplink PC
Uplink Report PC
707
6
SatelliteGuys.US DishNetwork Uplink Report - 6/08/2016 13:58 - 66 Changes
Uplink Comparison Range: 6/08/2016 13:55 - 6/08/2016 13:58 (PST)
MAP Changed:
4971 - DISH [MPEG2 SD] EchoStar14 119W TP 14 ConUS renamed to LOCAL , changed to Available , map (10) added (LOCAL)(Mkt: Chicago,IL)(A)(H)
4971 - DISH [MPEG4 SD] Nimiq5 72.7W TP 22 ConUS renamed to LOCAL , changed to Available , map (10) added (LOCAL)(Mkt: Chicago,IL)(A)(H)
4972 - DISH [MPEG2 SD] EchoStar14 119W TP 14 ConUS renamed to LOCAL , changed to Available , map (9) added (LOCAL)(Mkt: Cleveland,OH)(A)(H)
4972 - DISH [MPEG4 SD] Nimiq5 72.7W TP 22 ConUS renamed to LOCAL , changed to Available , map (9) added (LOCAL)(Mkt: Cleveland,OH)(A)(H)
4973 - DISH [MPEG2 SD] EchoStar14 119W TP 14 ConUS renamed to LOCAL , changed to Available , map (34) added (LOCAL)(Mkt: Dallas,TX)(A)(H)
4973 - DISH [MPEG4 SD] Nimiq5 72.7W TP 22 ConUS renamed to LOCAL , changed to Available , map (34) added (LOCAL)(Mkt: Dallas,TX)(A)(H)
4974 - DISH [MPEG2 SD] EchoStar14 119W TP 14 ConUS renamed to LOCAL , changed to Available , map (9) added (LOCAL)(Mkt: Davenport,IA)(A)(H)
4974 - DISH [MPEG4 SD] Nimiq5 72.7W TP 22 ConUS renamed to LOCAL , changed to Available , map (9) added (LOCAL)(Mkt: Davenport,IA)(A)(H)
4975 - DISH [MPEG2 SD] EchoStar14 119W TP 14 ConUS renamed to LOCAL , changed to Available , map (32) added (LOCAL)(Mkt: Denver,CO)(A)(H)
4975 - DISH [MPEG4 SD] Nimiq5 72.7W TP 22 ConUS renamed to LOCAL , changed to Available , map (32) added (LOCAL)(Mkt: Denver,CO)(A)(H)
4976 - DISH [MPEG2 SD] EchoStar14 119W TP 14 ConUS renamed to LOCAL , changed to Available , map (14) added (LOCAL)(Mkt: Des Moines,IA)(A)(H)
4976 - DISH [MPEG4 SD] Nimiq5 72.7W TP 22 ConUS renamed to LOCAL , changed to Available , map (14) added (LOCAL)(Mkt: Des Moines,IA)(A)(H)
4977 - DISH [MPEG2 SD] EchoStar14 119W TP 14 ConUS renamed to LOCAL , changed to Available , map (6) added (LOCAL)(Mkt: Ft. Smith,AR)(A)(H)
4977 - DISH [MPEG4 SD] Nimiq5 72.7W TP 22 ConUS renamed to LOCAL , changed to Available , map (6) added (LOCAL)(Mkt: Ft. Smith,AR)(A)(H)
4978 - DISH [MPEG2 SD] EchoStar14 119W TP 14 ConUS renamed to LOCAL , changed to Available , map (18) added (LOCAL)(Mkt: Grand Rapids,MI)(A)(H)
4978 - DISH [MPEG4 SD] Nimiq5 72.7W TP 22 ConUS renamed to LOCAL , changed to Available , map (18) added (LOCAL)(Mkt: Grand Rapids,MI)(A)(H)
4979 - DISH [MPEG2 SD] EchoStar14 119W TP 14 ConUS renamed to LOCAL , changed to Available , map (9) added (LOCAL)(Mkt: Greensboro,NC)(A)(H)
4979 - DISH [MPEG4 SD] Nimiq5 72.7W TP 22 ConUS renamed to LOCAL , changed to Available , map (9) added (LOCAL)(Mkt: Greensboro,NC)(A)(H)
4980 - DISH [MPEG2 SD] EchoStar14 119W TP 14 ConUS renamed to LOCAL , changed to Available , map (44) added (LOCAL)(Mkt: Harrisburg,PA)(A)(H)
4980 - DISH [MPEG4 SD] Nimiq5 72.7W TP 22 ConUS renamed to LOCAL , changed to Available , map (44) added (LOCAL)(Mkt: Harrisburg,PA)(A)(H)
4981 - DISH [MPEG2 SD] EchoStar14 119W TP 14 ConUS renamed to LOCAL , changed to Available , map (62) added (LOCAL)(Mkt: Hartford,CT)(A)(H)
4981 - DISH [MPEG4 SD] Nimiq5 72.7W TP 22 ConUS renamed to LOCAL , changed to Available , map (62) added (LOCAL)(Mkt: Hartford,CT)(A)(H)
4982 - DISH [MPEG2 SD] EchoStar14 119W TP 14 ConUS renamed to LOCAL , changed to Available , map (40) added (LOCAL)(Mkt: Houston,TX)(A)(H)
4982 - DISH [MPEG4 SD] Nimiq5 72.7W TP 22 ConUS renamed to LOCAL , changed to Available , map (40) added (LOCAL)(Mkt: Houston,TX)(A)(H)
4983 - DISH [MPEG2 SD] EchoStar14 119W TP 14 ConUS renamed to LOCAL , changed to Available , map (20) added (LOCAL)(Mkt: Huntsville,AL)(A)(H)
4983 - DISH [MPEG4 SD] Nimiq5 72.7W TP 22 ConUS renamed to LOCAL , changed to Available , map (20) added (LOCAL)(Mkt: Huntsville,AL)(A)(H)
4984 - DISH [MPEG2 SD] EchoStar14 119W TP 14 ConUS renamed to LOCAL , changed to Available , map (5) added (LOCAL)(Mkt: Indianapolis,IN)(A)(H)
4984 - DISH [MPEG4 SD] Nimiq5 72.7W TP 22 ConUS renamed to LOCAL , changed to Available , map (5) added (LOCAL)(Mkt: Indianapolis,IN)(A)(H)
4985 - DISH [MPEG2 SD] EchoStar14 119W TP 14 ConUS renamed to LOCAL , changed to Available , map (3) added (LOCAL)(Mkt: Kansas City,MO)(A)(H)
4985 - DISH [MPEG4 SD] Nimiq5 72.7W TP 22 ConUS renamed to LOCAL , changed to Available , map (3) added (LOCAL)(Mkt: Kansas City,MO)(A)(H)
4986 - DISH [MPEG2 SD] EchoStar14 119W TP 14 ConUS renamed to LOCAL , changed to Available , map (8) added (LOCAL)(Mkt: Los Angeles,CA)(A)(H)
4986 - DISH [MPEG4 SD] Nimiq5 72.7W TP 22 ConUS renamed to LOCAL , changed to Available , map (8) added (LOCAL)(Mkt: Los Angeles,CA)(A)(H)
4987 - DISH [MPEG2 SD] EchoStar14 119W TP 14 ConUS renamed to LOCAL , changed to Available , map (2) added (LOCAL)(Mkt: Memphis,TN)(A)(H)
4987 - DISH [MPEG4 SD] Nimiq5 72.7W TP 22 ConUS renamed to LOCAL , changed to Available , map (2) added (LOCAL)(Mkt: Memphis,TN)(A)(H)
4988 - DISH [MPEG2 SD] EchoStar14 119W TP 14 ConUS renamed to LOCAL , changed to Available , map (40) added (LOCAL)(Mkt: Miami,FL)(A)(H)
4988 - DISH [MPEG4 SD] Nimiq5 72.7W TP 22 ConUS renamed to LOCAL , changed to Available , map (40) added (LOCAL)(Mkt: Miami,FL)(A)(H)
4989 - DISH [MPEG2 SD] EchoStar14 119W TP 14 ConUS renamed to LOCAL , changed to Available , map (7) added (LOCAL)(Mkt: Milwaukee,WI)(A)(H)
4989 - DISH [MPEG4 SD] Nimiq5 72.7W TP 22 ConUS renamed to LOCAL , changed to Available , map (7) added (LOCAL)(Mkt: Milwaukee,WI)(A)(H)
4990 - DISH [MPEG2 SD] EchoStar14 119W TP 14 ConUS renamed to LOCAL , changed to Available , map (27) added (LOCAL)(Mkt: New Orleans,LA)(A)(H)
4990 - DISH [MPEG4 SD] Nimiq5 72.7W TP 22 ConUS renamed to LOCAL , changed to Available , map (27) added (LOCAL)(Mkt: New Orleans,LA)(A)(H)
4991 - DISH [MPEG2 SD] EchoStar14 119W TP 14 ConUS renamed to LOCAL , changed to Available , map (12) added (LOCAL)(Mkt: New York,NY)(A)(H)
4991 - DISH [MPEG4 SD] Nimiq5 72.7W TP 22 ConUS renamed to LOCAL , changed to Available , map (12) added (LOCAL)(Mkt: New York,NY)(A)(H)
4992 - DISH [MPEG2 SD] EchoStar14 119W TP 14 ConUS renamed to LOCAL , changed to Available , map (5) added (LOCAL)(Mkt: Norfolk,VA)(A)(H)
4992 - DISH [MPEG4 SD] Nimiq5 72.7W TP 22 ConUS renamed to LOCAL , changed to Available , map (5) added (LOCAL)(Mkt: Norfolk,VA)(A)(H)
4993 - DISH [MPEG2 SD] EchoStar14 119W TP 14 ConUS renamed to LOCAL , changed to Available , map (3) added (LOCAL)(Mkt: Oklahoma City,OK)(A)(H)
4993 - DISH [MPEG4 SD] Nimiq5 72.7W TP 22 ConUS renamed to LOCAL , changed to Available , map (3) added (LOCAL)(Mkt: Oklahoma City,OK)(A)(H)
4994 - DISH [MPEG2 SD] EchoStar14 119W TP 14 ConUS renamed to LOCAL , changed to Available , map (18) added (LOCAL)(Mkt: Philadelphia,PA)(A)(H)
4994 - DISH [MPEG4 SD] Nimiq5 72.7W TP 22 ConUS renamed to LOCAL , changed to Available , map (18) added (LOCAL)(Mkt: Philadelphia,PA)(A)(H)
4995 - DISH [MPEG2 SD] EchoStar14 119W TP 14 ConUS renamed to LOCAL , changed to Available , map (33) added (LOCAL)(Mkt: Portland,OR)(A)(H)
4995 - DISH [MPEG4 SD] Nimiq5 72.7W TP 22 ConUS renamed to LOCAL , changed to Available , map (33) added (LOCAL)(Mkt: Portland,OR)(A)(H)
4996 - DISH [MPEG2 SD] EchoStar14 119W TP 14 ConUS renamed to LOCAL , changed to Available , map (7) added (LOCAL)(Mkt: Richmond,VA)(A)(H)
4996 - DISH [MPEG4 SD] Nimiq5 72.7W TP 22 ConUS renamed to LOCAL , changed to Available , map (7) added (LOCAL)(Mkt: Richmond,VA)(A)(H)
4997 - DISH [MPEG2 SD] EchoStar14 119W TP 14 ConUS renamed to LOCAL , changed to Available , map (41) added (LOCAL)(Mkt: Sacramento,CA)(A)(H)
4997 - DISH [MPEG4 SD] Nimiq5 72.7W TP 22 ConUS renamed to LOCAL , changed to Available , map (41) added (LOCAL)(Mkt: Sacramento,CA)(A)(H)
4998 - DISH [MPEG2 SD] EchoStar14 119W TP 14 ConUS renamed to LOCAL , changed to Available , map (14) added (LOCAL)(Mkt: Salt Lake City,UT)(A)(H)
4998 - DISH [MPEG4 SD] Nimiq5 72.7W TP 22 ConUS renamed to LOCAL , changed to Available , map (14) added (LOCAL)(Mkt: Salt Lake City,UT)(A)(H)
4999 - DISH [MPEG2 SD] EchoStar14 119W TP 14 ConUS renamed to LOCAL , changed to Available , map (68) added (LOCAL)(Mkt: San Diego,CA)(A)(H)
4999 - DISH [MPEG4 SD] Nimiq5 72.7W TP 22 ConUS renamed to LOCAL , changed to Available , map (68) added (LOCAL)(Mkt: San Diego,CA)(A)(H)
5000 - DISH [MPEG2 SD] EchoStar14 119W TP 14 ConUS renamed to LOCAL , changed to Available , map (14) added (LOCAL)(Mkt: Seattle,WA)(A)(H)
5000 - DISH [MPEG4 SD] Nimiq5 72.7W TP 22 ConUS renamed to LOCAL , changed to Available , map (14) added (LOCAL)(Mkt: Seattle,WA)(A)(H)
5001 - DISH [MPEG2 SD] EchoStar14 119W TP 14 ConUS renamed to LOCAL , changed to Available , map (3) added (LOCAL)(Mkt: St. Louis,MO)(A)(H)
5001 - DISH [MPEG4 SD] Nimiq5 72.7W TP 22 ConUS renamed to LOCAL , changed to Available , map (3) added (LOCAL)(Mkt: St. Louis,MO)(A)(H)
5002 - DISH [MPEG2 SD] EchoStar14 119W TP 14 ConUS renamed to LOCAL , changed to Available , map (51) added (LOCAL)(Mkt: Washington,DC)(A)(H)
5002 - DISH [MPEG4 SD] Nimiq5 72.7W TP 22 ConUS renamed to LOCAL , changed to Available , map (51) added (LOCAL)(Mkt: Washington,DC)(A)(H)
5003 - DISH [MPEG2 SD] EchoStar14 119W TP 14 ConUS renamed to LOCAL , changed to Available , map (17) added (LOCAL)(Mkt: Wilkes Barre,PA)(A)(H)
5003 - DISH [MPEG4 SD] Nimiq5 72.7W TP 22 ConUS renamed to LOCAL , changed to Available , map (17) added (LOCAL)(Mkt: Wilkes Barre,PA)(A)(H)
Channels in the system: 9796
(A) = Available to subscribers
(NA) = Not Available
(H) = Hidden from non-subscribers
(FP) = Free Preview
The Format and Layout of the SatelliteGuys Uplink Report is © Copyright 2016 SatelliteGuys.US and may not be republished without written permission from SatelliteGuys.US.
SatelliteGuys Uplink PC Version 1.0.2
© 2016 - All Rights Reserved - SatelliteGuys Incorporated
They're not - they are putting these "dispute" channels NEAR to the actual channels in question...ch 10 f/Chicago is next to WGN-9; L.A. is for KTLA-5; St.Louis is for KPLR-11, Indianapolis is for WTTV-4, etc.
Hopefully WTTE as a replacement for WJW. WTTE is on the FCC's Significantly Viewed List for Richland County, Ohio.
This is NOT going to happen because DISH can ONLY offer SV stations in markets that are normally short a network affiliate - BUT NOT BECAUSE OF A RETRANS IMPASS! They are under more stringent rules than D* is, after their whole illegal selling of locals OUTSIDE their local markets.
They also CANNOT just substitute another affiliate out of market for this network - period. (whoever wrote that "article" has NO clue on how retrans works :rolleyes:
(edit) The ONLY exception to these rules...if any of these stations are carried in a DMA OUTSIDE their local DMA as an SV station, then E* could THEN pick another station of the same network, in a different out-of-market DMA. I know they have done this for a couple other retrans disputes.
Not entirely sure if this will affect the Tribune supers, since they are covered under completely different carriage rules. (WGN A is NO longer a super, so this wouldn't matter for it)
For example, this could affect the Lafayette, Indiana DMA. FOX could be brought in from Chicago instead of Indianapolis, because there is no FOX affiliate in the DMA. But if I understand correctly, it would not be legal to bring Chicago FOX into the Indianapolis DMA, because that DMA does have a FOX, WXIN (A Tribune station).
Reactions: dishrich
This is an example of how the entire DMA system is completely broken. In my opinion, the entire country needs to be broken down into even smaller, more locally-focused DMAs. For example, if Richland County, Ohio was its own separate one-station DMA (WMFD, an independent station) then any network affiliate could be brought in as a replacement during disputes, instead of leaving us stuck with Cleveland locals, or nothing at all.
Reactions: jegrant
how about a link to back this up?
Reactions: pattykay
I think if you go to the fcc site It does state that if a station does not work in good faith The a provider can import a out of market. It was something new that Tom Wheeler of the fcc introduced this year
Reactions: pattykay
Yea & I "think" if you attempt to post a link that this was actually allowed, you'd find it went NOWHERE fast...the NAB still has the power on these things.
Also, even if this WAS to be allowed, the provider (E*, D*, cable system, etc.) would still have to get retrans consent of the OOM station to import...which they probably would NOT entertain giving...so as to not step on their local channel counterparts toes. (because the same thing would probably happen eventually in reverse)
Think about it...if it HAD actually come to fruition, then we STILL wouldn't be having all these local channel disputes on ALL providers to this day???
Meanwhile the FCC is auctioning off everything above channel 30..the NAB is in its death throws
6/12/2016 11:30 - Uplink Report - 3 Changes
6/15/2016 12:24 - Uplink Report - 27 Changes
