6/11/2014 12:25 - Uplink Report - 52 Changes | SatelliteGuys.US
Uplink PC
Uplink Report PC
707
6
SatelliteGuys.US DishNetwork Uplink Report - 6/11/2014 12:25 - 52 Changes
Uplink Comparison Range: 6/11/2014 12:19 - 6/11/2014 12:25 (PST)
Channel Additions:
151 - WORLD [MPEG4 SD] added to Nimiq5 72.7W TP 31 ConUS (WORLD)(A)
151 - WORLD [MPEG2 SD] added to EchoStar11 110W TP 02 ConUS (WORLD)(A)
269 - WORLD [MPEG4 SD] added to Nimiq5 72.7W TP 31 ConUS (WORLD)(A)
269 - WORLD [MPEG2 SD] added to EchoStar11 110W TP 02 ConUS (WORLD)(A)
713 - FOOD2 [MPEG2 SD] added to Anik F3 118.7W TP 27 ConUS (FOOD2)(NA)(H)
874 - WORLD [MPEG4 SD] added to Nimiq5 72.7W TP 31 ConUS (WORLD)(A)
874 - WORLD [MPEG2 SD] added to EchoStar11 110W TP 02 ConUS (WORLD)(A)
5250(4) - WCIV [MPEG4 HD] added to Echostar16 61.5W TP 27 Spotbeam 33 (Mkt: Charleston,SC (SC-ABC))(NA)(H)
5251(5) - WCSC [MPEG4 HD] added to Echostar16 61.5W TP 27 Spotbeam 33 (Mkt: Charleston,SC (SC-CBS))(NA)(H)
5252(2) - WCBD [MPEG4 HD] added to Echostar16 61.5W TP 27 Spotbeam 33 (Mkt: Charleston,SC (SC-NBC))(NA)(H)
5253(24) - WTAT [MPEG4 HD] added to Echostar16 61.5W TP 27 Spotbeam 33 (Mkt: Charleston,SC (SC-FOX))(NA)(H)
5254(7) - WITV [MPEG4 HD] added to Echostar16 61.5W TP 30 Spotbeam 56 (Mkt: Charleston,SC (SC-PBS))(NA)(H)
5255(36) - WMMP [MPEG4 HD] added to Echostar16 61.5W TP 30 Spotbeam 56 (Mkt: Charleston,SC (SC-MN))(NA)(H)
5260(17) - WTVO [MPEG4 HD] added to Echostar16 61.5W TP 32 Spotbeam 08 (Mkt: Rockford,IL (IL-ABC))(NA)(H)
5261(23) - WIFR [MPEG4 HD] added to Echostar16 61.5W TP 32 Spotbeam 08 (Mkt: Rockford,IL (IL-CBS))(NA)(H)
5262(13) - WREX [MPEG4 HD] added to Echostar16 61.5W TP 32 Spotbeam 08 (Mkt: Rockford,IL (IL-NBC))(NA)(H)
5263(39) - WQRF [MPEG4 HD] added to Echostar16 61.5W TP 32 Spotbeam 08 (Mkt: Rockford,IL (IL-FOX))(NA)(H)
5270(13) - WMBB [MPEG4 HD] added to Echostar16 61.5W TP 30 Spotbeam 62 (Mkt: Panama City,FL (FL-ABC))(NA)(H)
5271(4) - WECP [MPEG4 HD] added to Echostar16 61.5W TP 30 Spotbeam 62 (Mkt: Panama City,FL (FL-CBS))(NA)(H)
5272(7) - WJHG [MPEG4 HD] added to Echostar16 61.5W TP 30 Spotbeam 62 (Mkt: Panama City,FL (FL-NBC))(NA)(H)
5273(28) - WPGX [MPEG4 HD] added to Echostar16 61.5W TP 30 Spotbeam 62 (Mkt: Panama City,FL (FL-FOX))(NA)(H)
5275(46) - WPCT [MPEG4 HD] added to Echostar16 61.5W TP 30 Spotbeam 62 (Mkt: Panama City,FL (FL-IND))(NA)(H)
5276(56) - WFSG [MPEG4 HD] added to Echostar16 61.5W TP 30 Spotbeam 62 (Mkt: Panama City,FL (FL-PBS))(NA)(H)
7548(60) - PBS [MPEG4 SD] added to Echostar16 61.5W TP 07 Conus (Mkt: Rockford,IL (USA-PBS))(NA)(H)
7892(50) - WCBDD [MPEG4 SD] added to Echostar16 61.5W TP 27 Spotbeam 33 (Mkt: Charleston,SC (SC-CW))(NA)(H)
7928(8) - WJHGD [MPEG4 SD] added to Echostar16 61.5W TP 30 Spotbeam 62 (Mkt: Panama City,FL (FL-CW))(NA)(H)
Channel Removals:
390 - FXX [MPEG4 SD] (A)(H) removed from Echostar16 61.5W TP 16 Conus (FXX)
390 - FXX [MPEG2 SD] (A)(H) removed from EchoStar14 119W TP 21 ConUS (FXX)
421 - DINFO [MPEG2 SD] (A)(H) removed from EchoStar10 110W TP 23 Spotbeam 12 (DINFO)
5421(421) - DINFO [MPEG4 HD] (A)(H) removed from EchoStar14 119W TP 07 ConUS (DINFO)
5421(421) - DINFO [MPEG4 HD] (A)(H) removed from Nimiq5 72.7W TP 01 ConUS (DINFO)
36850 - DNL8 [DATA] (A) removed from Quetzsat1 77W TP 28 ConUS (DNL8)
Channel Number Changed:
151 - APP [b8] Echostar16 61.5W TP 10 Conus map (151) added , channel number changed to 25021 (APP)(A)(FP)
151 - APP [b8] EchoStar11 110W TP 13 ConUS map (151) added , channel number changed to 25021 (APP)(A)(FP)
269 - APP [b8] Echostar16 61.5W TP 10 Conus map (269) added , channel number changed to 25022 (APP)(A)(FP)
269 - APP [b8] EchoStar11 110W TP 13 ConUS map (269) added , channel number changed to 25022 (APP)(A)(FP)
874 - APP [b8] Echostar16 61.5W TP 10 Conus map (874) added , channel number changed to 25023 (APP)(A)(FP)
874 - APP [b8] EchoStar11 110W TP 13 ConUS map (874) added , channel number changed to 25023 (APP)(A)(FP)
MAP Changed:
8061 - DINFO [MPEG4 SD] Echostar16 61.5W TP 16 Conus renamed to WPXH , moved to Echostar16 61.5W TP 13 Conus , map (44) added (Mkt: Birmingham,AL (AL-ION))(A)(H)
8061 - DINFO [MPEG2 SD] EchoStar14 119W TP 16 ConUS renamed to WPXH , moved to EchoStar14 119W TP 14 ConUS , map (44) added (Mkt: Birmingham,AL (AL-ION))(A)(H)
8399(9) - KWESD [MPEG2 SD] EchoStar10 110W TP 12 Spotbeam 27 changed to Available , map changed to (10) (KWESD)(Mkt: Odessa,TX)(A)(H)
Tier Changed:
5250(17) - WALBD [MPEG4 HD] Echostar16 61.5W TP 23 Spotbeam 10 changed to Available (Mkt: Albany,GA (GA - ABC))(A)(H)
5251(44) - WSWG [MPEG4 HD] Echostar16 61.5W TP 23 Spotbeam 10 changed to Available (Mkt: Albany,GA (GA - CBS))(A)(H)
5252(10) - WALB [MPEG4 HD] Echostar16 61.5W TP 23 Spotbeam 10 changed to Available (Mkt: Albany,GA (GA - NBC))(A)(H)
5253(31) - WFXL [MPEG4 HD] Echostar16 61.5W TP 23 Spotbeam 10 changed to Available (Mkt: Albany,GA (GA - FOX))(A)(H)
5255(14) - WABW [MPEG4 HD] Echostar16 61.5W TP 31 Spotbeam 10 changed to Available (Mkt: Albany,GA (GA-PBS))(A)(H)
7670(51) - WSST [MPEG4 SD] Echostar16 61.5W TP 23 Spotbeam 10 changed to Available (Mkt: Albany,GA (GA-IND))(A)(H)
9893 - POLO [MPEG2 SD] Anik F3 118.7W TP 30 ConUS changed to Available (POLO)(A)(H)
Channel Moves:
672 - OSNYH [MPEG2 SD] Anik F3 118.7W TP 07 ConUS moved to Anik F3 118.7W TP 03 ConUS (OSNYH)(A)(H)
36850 - DNL8 [DATA] Echostar16 61.5W TP 14 Conus moved to Nimiq5 72.7W TP 03 ConUS (DNL8)(A)
Name Changed:
100 - HOPVU [b8] Echostar16 61.5W TP 10 Conus renamed to MULTI (MULTI)(A)(FP)
100 - HOPVU [b8] EchoStar11 110W TP 13 ConUS renamed to MULTI (MULTI)(A)(FP)
Transponder Changes:
Echostar16 61.5W TP 07 Conus (21.500 8PSK 2/3) added.
Echostar16 61.5W TP 13 Conus (21.500 8PSK 2/3) added.
EchoStar11 110W TP 02 ConUS (20.000 QPSK 7/8) added.
Anik F3 118.7W TP 03 ConUS (20.000 QPSK 3/4) added.
Anik F3 118.7W TP 27 ConUS (20.000 QPSK 3/4) added.
Nimiq5 72.7W TP 03 ConUS (21.500 8PSK 2/3) added.
Nimiq5 72.7W TP 31 ConUS (21.500 8PSK 2/3) added.
Echostar16 61.5W TP 30 Spotbeam 62 (21.500 8PSK 3/4) added.
Echostar16 61.5W TP 32 Spotbeam 08 (21.500 8PSK 3/4) added.
Echostar16 61.5W TP 30 Spotbeam 56 (21.500 8PSK 3/4) added.
Echostar16 61.5W TP 27 Spotbeam 33 (21.500 8PSK 3/4) added.
EchoStar14 119W TP 07 ConUS (21.500 8PSK 2/3) removed.
EchoStar14 119W TP 16 ConUS (20.000 QPSK 7/8) removed.
EchoStar14 119W TP 21 ConUS (20.000 QPSK 7/8) removed.
Echostar16 61.5W TP 14 Conus (20.000 QPSK 7/8) removed.
Anik F3 118.7W TP 07 ConUS (20.000 QPSK 3/4) removed.
Quetzsat1 77W TP 28 ConUS (22.500 16-QAM 5/6) removed.
Nimiq5 72.7W TP 01 ConUS (21.500 8PSK 2/3) removed.
EchoStar10 110W TP 23 Spotbeam 12 (20.000 QPSK 5/6) removed.
Channels in the system: 9353
(A) = Available to subscribers
(NA) = Not Available
(H) = Hidden from non-subscribers
(FP) = Free Preview
The Format and Layout of the SatelliteGuys Uplink Report is © Copyright 2014 SatelliteGuys.US and may not be republished without written permission from SatelliteGuys.US.
SatelliteGuys Uplink PC Version 1.0.0
© 2014 - All Rights Reserved - SatelliteGuys Incorporated
Any idea when the local channels for Charleston, SC will be available on the Eastern Arc?
6/13/2014 09:35 - Uplink Report - 2 Changes
6/18/2014 18:10 - Uplink Report - 8 Changes
