6/25/2009 2:14am - Uplink Activity Report - 42 changes | SatelliteGuys.US
D
DigiDish Uplink Report
Guest
SatelliteGuys.US DishNetwork Uplink Activity Report - 6/25/2009 2:14am - 42 changes
Uplink Comparison Range: 06/25/2009 01:59A - 06/25/2009 02:13A
Channel Removals:
6151 - LTD14 (NA) removed from EchoStar11 110W TP 19 ConUS beam
6154 - LTD17 (NA) removed from EchoStar11 110W TP 19 ConUS beam
9584 - LTD4 (NA) removed from EchoStar11 110W TP 19 ConUS beam
Channel Moves:
151 - VS. [MPEG2 SD] moved from EchoStar11 110W TP 01 ConUS beam to EchoStar11 110W TP 21 ConUS beam (A)
155 - FUEL [MPEG2 SD] moved from EchoStar11 110W TP 19 ConUS beam to EchoStar11 110W TP 15 ConUS beam (A) (H)
177 - TOONW [MPEG2 SD] moved from EchoStar11 110W TP 19 ConUS beam to EchoStar11 110W TP 05 ConUS beam (A)
181 - N [MPEG2 SD] moved from EchoStar11 110W TP 19 ConUS beam to EchoStar11 110W TP 11 ConUS beam (A)
198 - SLTH [MPEG2 SD] moved from EchoStar11 110W TP 09 ConUS beam to EchoStar11 110W TP 01 ConUS beam (A)
217 - IONW [MPEG2 SD] moved from EchoStar11 110W TP 19 ConUS beam to EchoStar11 110W TP 01 ConUS beam (A)
233 - NOTAX [MPEG2 SD] moved from EchoStar11 110W TP 19 ConUS beam to EchoStar11 110W TP 01 ConUS beam (A) (H)
267 - CTN [MPEG2 SD] moved from EchoStar11 110W TP 19 ConUS beam to EchoStar11 110W TP 09 ConUS beam (A) (H)
402 - NBATV [MPEG2 SD] moved from EchoStar11 110W TP 01 ConUS beam to EchoStar11 110W TP 09 ConUS beam (A)
403 - NHLN [MPEG2 SD] moved from EchoStar11 110W TP 19 ConUS beam to EchoStar11 110W TP 15 ConUS beam (A)
511 - PPV [MPEG2 SD] moved from EchoStar11 110W TP 16 ConUS beam to EchoStar11 110W TP 14 ConUS beam (A)
512 - PPV [MPEG2 SD] moved from EchoStar11 110W TP 16 ConUS beam to EchoStar11 110W TP 14 ConUS beam (A)
560 - NBATV [MPEG2 SD] moved from EchoStar11 110W TP 01 ConUS beam to EchoStar11 110W TP 09 ConUS beam (A) (H)
625 - NHLN [MPEG2 SD] moved from EchoStar11 110W TP 19 ConUS beam to EchoStar11 110W TP 15 ConUS beam (A) (H)
834 - PSNES [MPEG2 SD] moved from EchoStar11 110W TP 19 ConUS beam to EchoStar11 110W TP 16 ConUS beam (A)
848 - CBBIS [MPEG2 SD] moved from EchoStar11 110W TP 19 ConUS beam to EchoStar11 110W TP 16 ConUS beam (A)
867 - BDMAX [MPEG2 SD] moved from EchoStar11 110W TP 19 ConUS beam to EchoStar11 110W TP 21 ConUS beam (A)
5801 - SKDL [MPEG2 SD] moved from EchoStar11 110W TP 16 ConUS beam to EchoStar11 110W TP 24 ConUS beam (NA)
5812 - SKDL [MPEG2 SD] moved from EchoStar11 110W TP 16 ConUS beam to EchoStar11 110W TP 24 ConUS beam (NA)
6152 - LTD15 [MPEG2 SD] moved from EchoStar11 110W TP 19 ConUS beam to EchoStar11 110W TP 11 ConUS beam (NA)
8025 - KPXN [MPEG2 SD] moved from EchoStar11 110W TP 19 ConUS beam to EchoStar11 110W TP 01 ConUS beam (A) (H)(San Bernardino, CA-N/A)
8909 - KPXO [MPEG2 SD] moved from EchoStar11 110W TP 19 ConUS beam to EchoStar11 110W TP 01 ConUS beam (A) (H)(Kaneohe, HI-ION)
9399 - CTN [MPEG2 SD] moved from EchoStar11 110W TP 19 ConUS beam to EchoStar11 110W TP 09 ConUS beam (A) (H)
9581 - LTD1 [MPEG2 SD] moved from EchoStar11 110W TP 19 ConUS beam to EchoStar11 110W TP 21 ConUS beam (NA)
9582 - LTD2 [MPEG2 SD] moved from EchoStar11 110W TP 19 ConUS beam to EchoStar11 110W TP 21 ConUS beam (NA)
9583 - LTD3 [MPEG2 SD] moved from EchoStar11 110W TP 19 ConUS beam to EchoStar11 110W TP 09 ConUS beam (NA)
14452 - KOMO2 [EPG] moved from EchoStar11 110W TP 19 ConUS beam to EchoStar11 110W TP 21 ConUS beam (NA)(Seattle, WA-ABC)
14468 - KXNE1 [EPG] moved from EchoStar11 110W TP 19 ConUS beam to EchoStar11 110W TP 21 ConUS beam (NA)(Norfolk, NE-PBS)
14469 - KXNE2 [EPG] moved from EchoStar11 110W TP 19 ConUS beam to EchoStar11 110W TP 21 ConUS beam (NA)(Norfolk, NE-PBS)
14470 - KXNE3 [EPG] moved from EchoStar11 110W TP 19 ConUS beam to EchoStar11 110W TP 21 ConUS beam (NA)(Norfolk, NE-PBS)
14471 - KXNE5 [EPG] moved from EchoStar11 110W TP 19 ConUS beam to EchoStar11 110W TP 21 ConUS beam (NA)(Norfolk, NE-PBS)
14601 - KSIN1 [EPG] moved from EchoStar11 110W TP 19 ConUS beam to EchoStar11 110W TP 21 ConUS beam (NA)(Sioux City, IA-PBS)
14619 - WGCL2 [EPG] moved from EchoStar11 110W TP 19 ConUS beam to EchoStar11 110W TP 21 ConUS beam (NA)(Atlanta, GA-CBS)
14620 - WGCL3 [EPG] moved from EchoStar11 110W TP 19 ConUS beam to EchoStar11 110W TP 21 ConUS beam (NA)(Atlanta, GA-CBS)
14622 - WXIA2 [EPG] moved from EchoStar11 110W TP 19 ConUS beam to EchoStar11 110W TP 21 ConUS beam (NA)(Atlanta, GA-NBC)
14769 - KIMA2 [EPG] moved from EchoStar11 110W TP 19 ConUS beam to EchoStar11 110W TP 21 ConUS beam (NA)(Yakima, WA-CBS)
19215 - HUNTT [DATA] moved from EchoStar11 110W TP 19 ConUS beam to EchoStar11 110W TP 09 ConUS beam (A)
19216 - HUNTV [DATA] moved from EchoStar11 110W TP 19 ConUS beam to EchoStar11 110W TP 09 ConUS beam (A)
Transponder Changes:
EchoStar11 110W TP 19 ConUS beam changed from 20000 QPSK 7/8 to 21500 8PSK 2/3
Channels in the system: 6559
(A) = Available to subscribers
(NA) = Not Available
(H) = Hidden from non-subscribers
So whats with the musical chairs on E11? Looks like TP 19 is getting close to being emptied again. Only Fuel, NHL, and 2 other channels in the 800 range.
Tp 19 is being cleared, and changed from QPSK to 8PSK. I'd say they're making room for more HD.
EDIT: It's back to QPSK in the 4:19 report with some SD channels being moved to it. Nice theory while it lasted.
Still the most empty TP on 110. My post reflects the morning changes as well.
OK, lets me prove it in Technical Forum.
No thanks... already verified.
5/13 - KPXO changed to Avail.
http://www.satelliteguys.us/dish-ne...-activity-report-235-changes.html#post1820459
Hit CTRL-F, type KPXO, see the little 66?
Ok... let's check today.
SatelliteGuys.US - Subscription 110°W
Hit CTRL-F, type KPXO again, see the little 66?
Please stop bothering me with these nonsense "missing from report" posts without checking your facts first. Due to your efforts to confuse users, your fruitless "missing from report" posts will be deleted and not replied to.
D
6/25/2009 4:19am - Uplink Activity Report - 8 changes
D
6/24/2009 12:29pm - Uplink Activity Report - 56 changes
