61.5 bird..xponder 24 turned off??? | SatelliteGuys.US
mrsat1
101
Seaford, NY
Just noticed transponder 24 @61.5 shows "not locked" with a red screen but a ss
of 106....All transponders even and odd are fine. Is there an issue with this transponder? I did hear there was a possible failure on this transponder...is this
true?? rolou21.
OK, if you insist ;) I'll make new sweep for you today.
BTW, there are many reasons to have high SS without lock: unknown SR to a receiver, SI data not matching definitions in current FW , etc.
[If you have sat feed and PC you could get Broadlogic card 2030 and after adding BLSA subboard to the card do it by yourself .]
EDIT. Added spectrograms. As you can see no SS at tp4, tp6, tp26 or tp28 today.
I am actually referring to transponder 24 not 22....but why is it showing not locked with a ss of 106??? rolou21.
That TP is active and kicking but does not contain any video streams. It isn't mapped in the system so that is why it isn't locking.
625 looses signal
721 Will Not Get Certain Channels
