61.5 using DTV DISH | SatelliteGuys.US
61.5 using DTV DISH
gary08
50
Hello,
I have a first generation Direct TV single LNB Dish, and I would like to know if I could use it to get the 61.5 feed.
I have a Dish 500/811 with a SW64 Switch (one open I/O left).
I could also use the ELEV. Azimuth (07650) for the 61.5 feed.
If I can use the dish, how would I go about locking it in on the 811? I get 110 and 119 plus the locals with a OAA right now.
Thanks,
Gary
615
gary08 said:
Hello,
Thanks,
Gary
Yes you should be able to use this but the LNB will need to be a dual as the SW64 locks one side of each LNB to odd or even. Go to point dish get your eleveation and direction there. Hook the direct dish dirtectly to your sat receiver bypassing the SW64 then Set the direct dish to that elevation point the dish in that direction swing it back and forth to find the sat tweak the elevation and direction to max signal hook the two coaxes from th direct LNB to your open two ports on your SW 64 run check switch on every receiver and you should be good to go
Another 522 backup thread (all hypothetical)
Problem with 510 and 105
