61.5 Working, But No Pic | SatelliteGuys.US
cjwct
1,598
8
Glastonbury, CT
I live near Hartford, CT and when I turned on WTNH for Celtics-Lakers game, I get the message that the signal has been lost; however, when I go into the system setup, all three locations are highlighted green and working fine . . . what gives? BTW no I cannot do OTA because this affiliate is over the Avon mountain :( :( :(
I have been fighting through the same problem for the past half hour. I can't offer a solution, I've been doing hard and soft resets....
wait as i typed that I got a pic back. totally screwy
i know the storm is coming through but it is at least a half hour-forty five minutes away; i went outside and the sky is clear for the most part; this sucks! well back to the dark ages . . . . . . . . SD :( :( :( thanks for the update/help
I'm further east (Rhode Island), and totally clear too, but after the hard restart (unplugged, waited 30 seconds, then plugged back in) and a longer than usual wait, the HD came back. Maybe that could (if you haven't tried already) work for you...good luck.
dacapo, thanks so much . . . worked like a charm; now the bigger question . . . what happened??? just my curiosity hard at work!
Msnbc Hd?
Saving recordings to External HD
