6x8 multiswitch.. take the place of diplexing? | SatelliteGuys.US
aec4
244
What are the other 2 inputs designed to accept on the 6x8 multiswitch? If it is OTA or Cable, what do you need to use on the other end to separate the signals?
dragon002 said:
on the other end (inside) you have to use diplexers to seperate the signals
I thought diplexers were out of the question for 5LNB dish?
If so, couldn't I replace my current diplexer solution with a 6x8 multiswitch (even though I only have 4 receivers), and put diplexers on the end of all the lines to separate the signals?
I believe the other two inputs are for the additional sat's at 72.5 and 95 degrees. You cannot use them for OTA or cable input. Diplexers are not an option :(
you didnt mention the 5 lnb dish, sorry
Sorry... I figured 6x8 signified that, my mistake.
What do you do in that situation ?
you can use a 6x8 with a phase 3 dish also.
what would I do?? run new coax for the ota that I wouldnt have:)
It's cable, not OTA.
And it's a necessity.
Run new coax from the second floor to the basement.. not so easy.
There is another switch you can use. It's 5x4 . That one has cable/antenna input . But you have only 4 outputs from that switch .....
I thought you had to use the 6x8 if you were using the 5lnb dish.
Updating Samsung DirectTV Tivo Unit software
moving HD to 101 satellite
