7/19/2012 4:01am - Uplink Activity Report - 90 changes | SatelliteGuys.US
D
DigiDish Uplink Report
Guest
SatelliteGuys.US DishNetwork Uplink Activity Report - 7/19/2012 4:01am - 90 changes
Uplink Comparison Range: 07/19/2012 03:46A - 07/19/2012 04:01A
Channel Additions:
6844 - UP11 [MPEG4 HD] added to EchoStar10 110W TP 12 Spotbeam 46/47 (Virtual Channel) (NA)
Channel Removals:
4585 - STYLE (A) (H) [MPEG4 HD] removed from Ciel-2 129W TP 32 ConUS beam (Style)
4603 - COOK (A) (H) [MPEG4 HD] removed from Ciel-2 129W TP 26 ConUS beam
4609 - DIY (A) (H) [MPEG4 HD] removed from Ciel-2 129W TP 32 ConUS beam (Do It Yourself Network)
4617 - H2 (A) (H) [MPEG4 HD] removed from Ciel-2 129W TP 26 ConUS beam
4623 - AMERI (A) (H) [MPEG4 HD] removed from EchoStar10 110W TP 27 Spotbeam 46/47
4706 - UNIHD (A) (H) [MPEG4 HD] removed from Ciel-2 129W TP 31 ConUS beam (Universal HD)
4761 - SPMAN (A) (H) [MPEG4 HD] removed from Ciel-2 129W TP 20 ConUS beam
4775 - FSC (A) (H) [MPEG4 HD] removed from Ciel-2 129W TP 20 ConUS beam (Fox Soccer Channel)
6806 - UP8 (NA) [MPEG2 SD] removed from EchoStar11 110W TP 22 ConUS beam (Virtual Channel)
6871 - UP29 (NA) [MPEG4 HD] removed from EchoStar14 119W TP 05 Spotbeam A20 (Virtual Channel)
Channel Moves:
8690 - WFTS [MPEG2 SD] moved from EchoStar10 110W TP 27 Spotbeam 01 to EchoStar14 119W TP 01 Spotbeam A20 (Mkt:Tampa, FL-Tampa, FL-ABC) (A) (H)
8691 - WTSP [MPEG2 SD] moved from EchoStar10 110W TP 27 Spotbeam 01 to EchoStar14 119W TP 01 Spotbeam A20 (Mkt:Tampa, FL-St. Petersburg, FL-CBS) (A) (H)
8692 - WFLA [MPEG2 SD] moved from EchoStar10 110W TP 27 Spotbeam 01 to EchoStar14 119W TP 01 Spotbeam A20 (Mkt:Tampa, FL-Tampa, FL-NBC) (A) (H)
8693 - WTVT [MPEG2 SD] moved from EchoStar10 110W TP 27 Spotbeam 01 to EchoStar14 119W TP 01 Spotbeam A20 (Mkt:Tampa, FL-Tampa, FL-FOX) (A) (H)
8694 - WTTA [MPEG2 SD] moved from EchoStar10 110W TP 27 Spotbeam 01 to EchoStar14 119W TP 01 Spotbeam A20 (Mkt:Tampa, FL-St. Petersburg, FL-MY) (A) (H)
8695 - WTOG [MPEG2 SD] moved from EchoStar10 110W TP 27 Spotbeam 01 to EchoStar14 119W TP 01 Spotbeam A20 (Mkt:Tampa, FL-St. Petersburg, FL-CW) (A) (H)
8696 - WEDU [MPEG2 SD] moved from EchoStar10 110W TP 27 Spotbeam 01 to EchoStar14 119W TP 01 Spotbeam A20 (Mkt:Tampa, FL-Tampa, FL-PBS) (A) (H)
8697 - WMOR [MPEG2 SD] moved from EchoStar10 110W TP 27 Spotbeam 01 to EchoStar14 119W TP 01 Spotbeam A20 (Mkt:Tampa, FL-Lakeland, FL-IND) (A) (H)
8698 - WVEA [MPEG2 SD] moved from EchoStar10 110W TP 27 Spotbeam 01 to EchoStar14 119W TP 01 Spotbeam A20 (Mkt:Tampa, FL-Tampa, FL-N/A) (A) (H)
8699 - WRMD [MPEG2 SD] moved from EchoStar10 110W TP 29 Spotbeam 01 to EchoStar14 119W TP 05 Spotbeam A20 (Mkt:Tampa, FL-Tampa, FL-N/A) (A) (H)
8700 - WFTT [MPEG2 SD] moved from EchoStar10 110W TP 27 Spotbeam 01 to EchoStar14 119W TP 01 Spotbeam A20 (Mkt:Tampa, FL-Tampa, FL-TEL) (A) (H)
8701 - WUSF [MPEG2 SD] moved from EchoStar10 110W TP 27 Spotbeam 01 to EchoStar14 119W TP 01 Spotbeam A20 (Mkt:Tampa, FL-Tampa, FL-PBS) (A) (H)
8702 - WCLF [MPEG2 SD] moved from EchoStar10 110W TP 27 Spotbeam 01 to EchoStar14 119W TP 01 Spotbeam A20 (Mkt:Tampa, FL-Clearwater, FL-N/A) (A) (H)
8703 - WXPX [MPEG2 SD] moved from EchoStar10 110W TP 27 Spotbeam 01 to EchoStar14 119W TP 01 Spotbeam A20 (Mkt:Tampa, FL-Bradenton, FL-N/A) (A) (H)
8704 - WXAX [MPEG2 SD] moved from EchoStar10 110W TP 29 Spotbeam 01 to EchoStar14 119W TP 05 Spotbeam A20 (Mkt:Tampa, FL-Clearwater, FL-N/A) (A) (H)
8705 - WWSB [MPEG2 SD] moved from EchoStar10 110W TP 29 Spotbeam 01 to EchoStar14 119W TP 05 Spotbeam A20 (Mkt:Tampa, FL-Sarasota, FL-ABC) (A) (H)
4111 - DIY [MPEG4 HD] moved from Ciel-2 129W TP 32 ConUS beam to EchoStar11 110W TP 22 ConUS beam (Do It Yourself Network) (A) (H)
4113 - COOK [MPEG4 HD] moved from Ciel-2 129W TP 26 ConUS beam to EchoStar11 110W TP 22 ConUS beam (A) (H)
4115 - STYLE [MPEG4 HD] moved from Ciel-2 129W TP 32 ConUS beam to EchoStar11 110W TP 22 ConUS beam (Style) (A) (H)
4121 - H2 [MPEG4 HD] moved from Ciel-2 129W TP 26 ConUS beam to EchoStar11 110W TP 22 ConUS beam (A) (H)
4149 - FSC [MPEG4 HD] moved from Ciel-2 129W TP 20 ConUS beam to EchoStar11 110W TP 22 ConUS beam (Fox Soccer Channel) (A) (H)
4187 - HMC [MPEG4 HD] moved from Ciel-2 129W TP 29 ConUS beam to EchoStar11 110W TP 22 ConUS beam (Hallmark Movie Channel) (A) (H)
4266 - UNIHD [MPEG4 HD] moved from Ciel-2 129W TP 31 ConUS beam to EchoStar11 110W TP 22 ConUS beam (Universal HD) (A) (H)
4337 - HMC [MPEG4 HD] moved from EchoStar10 110W TP 12 Spotbeam 46/47 to EchoStar11 110W TP 22 ConUS beam (Hallmark Movie Channel) (A) (H)
4339 - AMERI [MPEG4 HD] moved from EchoStar10 110W TP 27 Spotbeam 46/47 to EchoStar11 110W TP 19 ConUS beam (A) (H)
4354 - COOK [MPEG4 HD] moved from EchoStar10 110W TP 12 Spotbeam 46/47 to EchoStar11 110W TP 22 ConUS beam (A) (H)
4419 - H2 [MPEG4 HD] moved from EchoStar10 110W TP 12 Spotbeam 46/47 to EchoStar11 110W TP 22 ConUS beam (A) (H)
4422 - DIY [MPEG4 HD] moved from EchoStar10 110W TP 12 Spotbeam 46/47 to EchoStar11 110W TP 22 ConUS beam (Do It Yourself Network) (A) (H)
4423 - STYLE [MPEG4 HD] moved from EchoStar10 110W TP 12 Spotbeam 46/47 to EchoStar11 110W TP 22 ConUS beam (Style) (A) (H)
4585 - STYLE [MPEG4 HD] moved from EchoStar10 110W TP 12 Spotbeam 46/47 to EchoStar11 110W TP 22 ConUS beam (Style) (A) (H)
4603 - COOK [MPEG4 HD] moved from EchoStar10 110W TP 12 Spotbeam 46/47 to EchoStar11 110W TP 22 ConUS beam (A) (H)
4609 - DIY [MPEG4 HD] moved from EchoStar10 110W TP 12 Spotbeam 46/47 to EchoStar11 110W TP 22 ConUS beam (Do It Yourself Network) (A) (H)
4617 - H2 [MPEG4 HD] moved from EchoStar10 110W TP 12 Spotbeam 46/47 to EchoStar11 110W TP 22 ConUS beam (A) (H)
4706 - UNIHD [MPEG4 HD] moved from EchoStar10 110W TP 12 Spotbeam 46/47 to EchoStar11 110W TP 22 ConUS beam (Universal HD) (A) (H)
4761 - SPMAN [MPEG4 HD] moved from EchoStar10 110W TP 12 Spotbeam 46/47 to EchoStar11 110W TP 22 ConUS beam (A) (H)
4775 - FSC [MPEG4 HD] moved from EchoStar10 110W TP 12 Spotbeam 46/47 to EchoStar11 110W TP 22 ConUS beam (Fox Soccer Channel) (A) (H)
5306 - FSC [MPEG4 HD] moved from Ciel-2 129W TP 20 ConUS beam to EchoStar11 110W TP 22 ConUS beam (Fox Soccer Channel) (A) (H)
5346 - DIY [MPEG4 HD] moved from Ciel-2 129W TP 32 ConUS beam to EchoStar11 110W TP 22 ConUS beam (Do It Yourself Network) (A) (H)
5514 - ENCOR [MPEG4 HD] moved from EchoStar10 110W TP 27 Spotbeam 46/47 to EchoStar11 110W TP 19 ConUS beam (Encore (East)) (A) (H)
5523 - PIXL [MPEG4 HD] moved from EchoStar10 110W TP 29 Spotbeam 46/47 to EchoStar11 110W TP 22 ConUS beam (A) (H)
5524 - UNIHD [MPEG4 HD] moved from EchoStar10 110W TP 12 Spotbeam 46/47 to EchoStar11 110W TP 22 ConUS beam (Universal HD) (A) (H)
5530 - HMC [MPEG4 HD] moved from EchoStar10 110W TP 12 Spotbeam 46/47 to EchoStar11 110W TP 22 ConUS beam (Hallmark Movie Channel) (A) (H)
5560 - FSC [MPEG4 HD] moved from EchoStar10 110W TP 12 Spotbeam 46/47 to EchoStar11 110W TP 22 ConUS beam (Fox Soccer Channel) (A) (H)
5562 - SPMAN [MPEG4 HD] moved from EchoStar10 110W TP 12 Spotbeam 46/47 to EchoStar11 110W TP 22 ConUS beam (A) (H)
5564 - DIY [MPEG4 HD] moved from EchoStar10 110W TP 12 Spotbeam 46/47 to EchoStar11 110W TP 22 ConUS beam (Do It Yourself Network) (A) (H)
5566 - STYLE [MPEG4 HD] moved from EchoStar10 110W TP 12 Spotbeam 46/47 to EchoStar11 110W TP 22 ConUS beam (Style) (A) (H)
5568 - H2 [MPEG4 HD] moved from EchoStar10 110W TP 12 Spotbeam 46/47 to EchoStar11 110W TP 22 ConUS beam (A) (H)
5570 - COOK [MPEG4 HD] moved from EchoStar10 110W TP 12 Spotbeam 46/47 to EchoStar11 110W TP 22 ConUS beam (A) (H)
5576 - HMC [MPEG4 HD] moved from EchoStar10 110W TP 12 Spotbeam 46/47 to EchoStar11 110W TP 22 ConUS beam (Hallmark Movie Channel) (A) (H)
5598 - AMERI [MPEG4 HD] moved from EchoStar10 110W TP 27 Spotbeam 46/47 to EchoStar11 110W TP 19 ConUS beam (A) (H)
5910 - DIY [MPEG4 HD] moved from Ciel-2 129W TP 32 ConUS beam to EchoStar11 110W TP 22 ConUS beam (Do It Yourself Network) (NA)
5914 - COOK [MPEG4 HD] moved from Ciel-2 129W TP 26 ConUS beam to EchoStar11 110W TP 22 ConUS beam (NA)
5926 - H2 [MPEG4 HD] moved from Ciel-2 129W TP 26 ConUS beam to EchoStar11 110W TP 22 ConUS beam (NA)
6868 - UP29 [MPEG4 HD] moved from EchoStar14 119W TP 01 Spotbeam A20 to EchoStar10 110W TP 27 Spotbeam 01 (Virtual Channel) (NA)
9418 - PIXL [MPEG4 HD] moved from Ciel-2 129W TP 20 ConUS beam to EchoStar11 110W TP 22 ConUS beam (A)
9427 - UNIHD [MPEG4 HD] moved from Ciel-2 129W TP 31 ConUS beam to EchoStar11 110W TP 22 ConUS beam (Universal HD) (A)
9428 - STYLE [MPEG4 HD] moved from Ciel-2 129W TP 32 ConUS beam to EchoStar11 110W TP 22 ConUS beam (Style) (A)
9444 - HMC [MPEG4 HD] moved from Ciel-2 129W TP 29 ConUS beam to EchoStar11 110W TP 22 ConUS beam (Hallmark Movie Channel) (A)
9447 - COOK [MPEG4 HD] moved from Ciel-2 129W TP 26 ConUS beam to EchoStar11 110W TP 22 ConUS beam (A)
9483 - SPMAN [MPEG4 HD] moved from Ciel-2 129W TP 20 ConUS beam to EchoStar11 110W TP 22 ConUS beam (A)
9520 - FSC [MPEG4 HD] moved from Ciel-2 129W TP 20 ConUS beam to EchoStar11 110W TP 22 ConUS beam (Fox Soccer Channel) (A)
9525 - H2 [MPEG4 HD] moved from Ciel-2 129W TP 26 ConUS beam to EchoStar11 110W TP 22 ConUS beam (A)
9527 - DIY [MPEG4 HD] moved from Ciel-2 129W TP 32 ConUS beam to EchoStar11 110W TP 22 ConUS beam (Do It Yourself Network) (A)
9605 - STYLE [MPEG4 HD] moved from Ciel-2 129W TP 32 ConUS beam to EchoStar11 110W TP 22 ConUS beam (Style) (A) (H)
14115 - WEDU2 [EPG] moved from EchoStar10 110W TP 27 Spotbeam 01 to EchoStar14 119W TP 01 Spotbeam A20 (OTA EPG:Tampa, FL)(NA)
14117 - WUSF2 [EPG] moved from EchoStar10 110W TP 27 Spotbeam 01 to EchoStar14 119W TP 01 Spotbeam A20 (OTA EPG:Tampa, FL)(NA)
14118 - WUSF3 [EPG] moved from EchoStar10 110W TP 27 Spotbeam 01 to EchoStar14 119W TP 01 Spotbeam A20 (OTA EPG:Tampa, FL)(NA)
14119 - WUSF4 [EPG] moved from EchoStar10 110W TP 27 Spotbeam 01 to EchoStar14 119W TP 01 Spotbeam A20 (OTA EPG:Tampa, FL)(NA)
14120 - WXPX2 [EPG] moved from EchoStar10 110W TP 27 Spotbeam 01 to EchoStar14 119W TP 01 Spotbeam A20 (OTA EPG:Bradenton, FL)(NA)
14121 - WXPX3 [EPG] moved from EchoStar10 110W TP 27 Spotbeam 01 to EchoStar14 119W TP 01 Spotbeam A20 (OTA EPG:Bradenton, FL)(NA)
14122 - WFTS2 [EPG] moved from EchoStar10 110W TP 27 Spotbeam 01 to EchoStar14 119W TP 01 Spotbeam A20 (OTA EPG:Tampa, FL)(NA)
14516 - WEDU3 [EPG] moved from EchoStar10 110W TP 27 Spotbeam 01 to EchoStar14 119W TP 01 Spotbeam A20 (OTA EPG:Tampa, FL)(NA)
14902 - WFLA2 [EPG] moved from EchoStar10 110W TP 27 Spotbeam 01 to EchoStar14 119W TP 01 Spotbeam A20 (OTA EPG:Tampa, FL)(NA)
14964 - WTTA2 [EPG] moved from EchoStar10 110W TP 27 Spotbeam 01 to EchoStar14 119W TP 01 Spotbeam A20 (OTA EPG:St. Petersburg, FL)(NA)
15102 - WTSP2 [EPG] moved from EchoStar10 110W TP 27 Spotbeam 01 to EchoStar14 119W TP 01 Spotbeam A20 (OTA EPG:St. Petersburg, FL)(NA)
15127 - WCLF2 [EPG] moved from EchoStar10 110W TP 27 Spotbeam 01 to EchoStar14 119W TP 01 Spotbeam A20 (OTA EPG:Clearwater, FL)(NA)
15135 - WVEA2 [EPG] moved from EchoStar10 110W TP 27 Spotbeam 01 to EchoStar14 119W TP 01 Spotbeam A20 (OTA EPG:Tampa, FL)(NA)
15179 - WEDU4 [EPG] moved from EchoStar10 110W TP 27 Spotbeam 01 to EchoStar14 119W TP 01 Spotbeam A20 (OTA EPG:Tampa, FL)(NA)
Transponder Changes:
EchoStar10 110W TP 12 Spotbeam 01 changed from 21500 8PSK 2/3 to 20000 QPSK 5/6
Channels in the system: 8453
(A) = Available to subscribers
(NA) = Not Available
(H) = Hidden from non-subscribers
(FP) = Free Preview
The Format and Layout of the SatelliteGuys Uplink Report is © Copyright 2012 SatelliteGuys.US and may not be republished without written permission from SatelliteGuys.US.
The SatelliteGuys Uplink Report is powered by Digiblur Technologies! - DigiDish v12.04.10
© 2012 - All Rights Reserved - SatelliteGuys Incorporated
dish moved some alaska/hawaii HD channels from 110 spotbeam to conus and 129 to 110? now there is no excuses (again!!!) to made those available to PR too!!! or something went wrong with 129?
Let see what dish do...although some of those channels were already available for PR subs. Seems like Dish might be consolidating some of these channels...which IMO is good move. No need to have duplicate channel...eg...WGN is on Conus...but it also is on PR spot beam....hence occuping a slot for another HD for PR subs....eg...will like Dish to give us HD of science channel...on PR spot beam..instead of WGN which is already on Conus
DIY, COOK, STYLE, H2, UNIHD, HMC, AMERI, SPMAN, PIXL, ENCOR are 10 channels that can be added to PR subs now using ConUS, not by spotbeam since the vast majority of SD subbed channels for PR are ConUS. is nice to dream awake!!! :haha:haha:haha
^^ Encore is already in HD in PR....& I think AMERI is also available in HD (I think I saw it in HD when it was in free preview).
But yes...will be nice to see them in HD...if the subs are having the correct package. I will probably get couple in HD only as I am in AT200
i'm at AEP, thanks for the tip about encore, i confirmed that it opens with my sub in HD, but AMERI (formerly GREEN?) is not in HD using hoppers in PR, only in SD
AmeriHd was there till a few days ago. Just checked and only see the sd version.
Exactly....I am sure I was getting Ameri HD when it was on free preview. But it appears Dish has finally moved that channel in HD to Conus when PR subs can see also. Even though this channel is not in my package (AT200)...will be welcome to AT250 subs to get it in HD.
i didn't check it if the HD version of Destination America was available when free preview was up, but at AEP, it has to be available all the time. formerly GREEN was available for PR at 4935 slot, but was removed by copyright issues (excuses?) and the same happened to CI:
4933 - CI (A) (H) [MPEG4 HD] removed from EchoStar11 110W TP 09 ConUS beam(Crime & Investigation Network HD)
4935 - GREEN (A) (H) [MPEG4 HD] removed from EchoStar11 110W TP 09 ConUS beam(Planet Green)
http://www.satelliteguys.us/dish-network-uplink-center-archive/216315-6-9-2010-3-25pm-uplink.html
http://www.satelliteguys.us/dish-forum/215450-page-ranking-lost-2-hd-channels.html?highlight=4935
maybe that's why was only available at free preview
D
7/19/2012 4:17pm - Uplink Activity Report - 2 changes
D
7/22/2012 1:31am - Uplink Activity Report - 1 change
