72.0w | SatelliteGuys.US
72.0w
cruzin
323
michigan
Hi, can someone tell me if the 72.0 sat is a linear sat? I read that there are NFL Sunday night wild feeds there and I moved my dish to it and cant get any signal there. Using cs5000, 10.M channel master with dg380, linear lnb set at 10750. thanks
Checked Lyngsat, NBC Mux at 12053/v/6890 is always good for sat alignment. Don't be surprised after you do a blind scan that some station will not be viewable you would need a newer HD STB.
Mike Lib
- Sadoun would be proud:
I know he loves good stories about his hardware.
But, this is really is a heck of a testimonial: "...10.M channel master with dg380..."
Sorry for the misleading! guess couldnt pull one over on you! my period is in the wrong place! should be 1.0M
Superdish question
Is it raining in Baton Rouge, LA
