722K/722 TV 2 Remote swap? | SatelliteGuys.US
stimpson
Miller Lite Tester
4,701
46
Benton, Arkansas
When I got my 722K installed, the installer set up a 6.3 IR/UHF Pro as a second TV 2 remote because I have TV2 split to two rooms and didn't want to be chaseing one remote back and forth. Did some swapping of the 722 and 722K for trouble shooting and now I think I want to keep the receivers in the swapped locations. Question one is, what do I have to do to make the 6.3 work with the 722 TV2. When I had them swapped I tried to control TV2 from the 722 and it didn't work. Question two is, can a 722K remote be used to control a 722? Thanks.
The TV2 remote address is probably different for both receivers (which it should be). And yes, 722K remote will control 722.
Thanks for the reply KAB. So I just need to check the address, and change as needed on the 6.3? Will that apply the the 722K remotes as well? One other question. Did you happen to see the thread I started the other day about my 722K problem?
720 p or 1080i
Can't get my remote to work...
