I'm not sure what resolution the hp 2009m will support. Any way I can hook tv2 up to it
Ah... According to the link you gave,The HP 2009M will support up to 1600x900 resolution. You could use one of these guys and hook it up to either the TV1 or TV2 composite output.
For only $1.62 each when QTY 50+ purchased - VGA to S-Video/RCA (Composite) Adapter Cable - Black | VGA <--> S-Video/RCA
IMPORTANT:
- THIS ADAPTER WILL ABSOLUTELY NOT CONVERT AN S-VIDEO OR COMPOSITE VIDEO SIGNAL TO VGA. IT WILL NOT WORK BACKWARDS.
- YOU CAN NOT USE IT TO DRIVE A VGA COMPUTER MONITOR WITH A CONSUMER ELECTRONICS DEVICE SUCH AS A DVD PLAYER OR VCR.
- IT IS NOT COMPATIBLE WITH NETBOOKS OR ANY CURRENT GRAPHIC CHIPSET.
Sounds like it only does vga to composit not the other way around. What else do I need if I want to hook up to tv 2.
It does VGA to composite only for those video adapters that have a TV-out on the "correct" VGA pins...Sounds like it only does vga to composit not the other way around. What else do I need if I want to hook up to tv 2.
Limited time offer
