75 cm Hotdish | SatelliteGuys.US
75 cm Hotdish
mchomicz
SatelliteGuys Guru
I am looking to get a second dish as cheap as possible. I have located a source where I can this product http://www.dmsiusa.com/hotdish75.htm - 75cm HotDish - for $50 delivered.
1. Is this a good price on a 75cm HotDish?
2. Can I get something - ANTHING - cheaper than that? Tinfoil is OK :D
3. Does anybody have a first hand experience with the 75 cm HotDish? How is it working out for you?
Thank you,
Michael
that's damn good
unless its rigged...no
Thank you,
Michael
I have used one of these aimed at Galaxy 10 for over a year now. I bought one and would ghetto move it to the satellites, until I got my Winegard and motor.
They are real good units…the only thing I recommend is when you tighten the bolts, don't over tighten because you will warp the dish
New? Most likly not.
Used: Find a Primestar dish that someone wants removed.
Is this $50 with or without LNBF?
Thank you,
Michael
Just the dish. No LNB.
I have and am trying. So far was only able to find DirecTV / Dish Network dishes or C-band...
Thanks,
Michael
Dual LNB Bracket
Directv Dish/FTA Question
