8/19/2009 12:29pm - Uplink Activity Report - 49 changes | SatelliteGuys.US
D
DigiDish Uplink Report
Guest
SatelliteGuys.US DishNetwork Uplink Activity Report - 8/19/2009 12:29pm - 49 changes
Uplink Comparison Range: 08/19/2009 12:14P - 08/19/2009 12:28P
Channel Additions:
8799(17) - KBNT [MPEG2 SD] added to EchoStar10 110W TP 27 Spotbeam 39 (NA)(San Diego, CA-N/A)
5191(22) - WSBT [MPEG4 HD] added to Echostar12 61.5W TP 05 Spotbeam 11 (NA)(South Bend, IN-CBS)
5200(33) - KSPR [MPEG4 HD] added to EchoStar8 77W TP 17 ConUS beam (NA)(Springfield, MO-ABC)
5202(3) - KYTV [MPEG4 HD] added to EchoStar8 77W TP 17 ConUS beam (NA)(Springfield, MO-NBC)
8168(39) - WLVT [MPEG2 SD] added to EchoStar10 110W TP 26 Spotbeam 04 (NA)(Allentown, PA-N/A)
8168(39) - WLVT [MPEG4 SD] added to Echostar12 61.5W TP 11 Spotbeam 4 (NA)(Allentown, PA-N/A)
1 - VOD1 [176] added to EchoStar11 110W TP 21 ConUS beam (NA)
1 - VOD1 [176] added to EchoStar3 61.5W TP 29 ConUS beam (NA)
1 - VOD1 [176] added to Echostar6 72.7W TP 21 ConUS beam (NA)
156 - FUEL [MPEG2 SD] added to EchoStar11 110W TP 15 ConUS beam (A)
156 - FUEL [MPEG4 SD] added to Echostar6 72.7W TP 11 ConUS beam (A)
748 - DAWN [MPEG2 SD] added to Anik F3 118.7W TP 25 ConUS beam (NA)
8795(34) - XHAS [MPEG2 SD] added to EchoStar10 110W TP 27 Spotbeam 39 (NA)
9315(30) - WVLTD [MPEG2 SD] added to EchoStar10 110W TP 12 Spotbeam 10 (NA)
9315(30) - WVLTD [MPEG4 SD] added to Echostar12 61.5W TP 07 Spotbeam 6 (NA)
9373 - KIMAD [MPEG2 SD] added to EchoStar10 110W TP 12 Spotbeam 45 (NA)
Channel Removals:
156 - MUSIC (A) removed from EchoStar11 110W TP 10 ConUS beam
156 - MUSIC (A) removed from Echostar6 72.7W TP 07 ConUS beam
5743 - IAD14 (A) removed from EchoStar11 110W TP 08 ConUS beam
Channel Package Flag Changes:
6540(31) - KLAX [MPEG2 SD 8PSK] - Ciel-2 129W TP 09 Spotbeam 42 changed to Available (H)(Alexandria, LA-ABC)
6541(35) - KALBD [MPEG2 SD 8PSK] - Ciel-2 129W TP 09 Spotbeam 42 changed to Available (H)(Alexandria, LA-CBS)
6542(5) - KALB [MPEG2 SD 8PSK] - Ciel-2 129W TP 09 Spotbeam 42 changed to Available (H)(Alexandria, LA-NBC)
6544(41) - KBCA [MPEG2 SD 8PSK] - Ciel-2 129W TP 09 Spotbeam 42 changed to Available (H)(Alexandria, LA-CW)
6545(26) - KLPA [MPEG2 SD 8PSK] - Ciel-2 129W TP 09 Spotbeam 42 changed to Available (H)(Alexandria, LA-PBS)
6521(3) - WJMN [MPEG2 SD] - Ciel-2 129W TP 12 Spotbeam 15 changed to Available (H)(Escanaba, MI-CBS)
5251(4) - WCBI [MPEG4 HD] - Ciel-2 129W TP 13 Spotbeam 38 changed to Available (H)(Columbus, MS-CBS)
5250(45) - WKDH [MPEG4 HD] - Ciel-2 129W TP 13 Spotbeam 38 changed to Available (H)(Houston, MS-ABC)
6543(48) - WNTZ [MPEG2 SD 8PSK] - Ciel-2 129W TP 09 Spotbeam 42 changed to Available (H)(Natchez, MS-FOX)
5252(9) - WTVA [MPEG4 HD] - Ciel-2 129W TP 13 Spotbeam 38 changed to Available (H)(Tupelo, MS-NBC)
5253(27) - WLOV [MPEG4 HD] - Ciel-2 129W TP 13 Spotbeam 38 changed to Available (H)(West Point, MS-FOX)
9041(32) - KMCC [MPEG2 SD] - EchoStar10 110W TP 12 Spotbeam 38 changed to Available (H)(Laughlin, NV-N/A)
6585(27) - WBGU [MPEG2 SD] - Ciel-2 129W TP 06 Spotbeam 25 changed to Available (H)(Bowling Green, OH-PBS)
6580(18) - WLQP [MPEG2 SD] - Ciel-2 129W TP 06 Spotbeam 25 changed to Available (H)(Lima, OH-ABC)
6582(8) - WLIO [MPEG2 SD] - Ciel-2 129W TP 06 Spotbeam 25 changed to Available (H)(Lima, OH-NBC)
6583(25) - WOHL [MPEG2 SD] - Ciel-2 129W TP 06 Spotbeam 25 changed to Available (H)(Lima, OH-FOX)
6584(44) - WTLW [MPEG2 SD] - Ciel-2 129W TP 06 Spotbeam 25 changed to Available (H)(Lima, OH-IND)
5116(3) - KOTA [MPEG2 SD] - Ciel-2 129W TP 02 Spotbeam 13 changed to Available (H)(Rapid City, SD-ABC)
5117(15) - KCLO [MPEG2 SD] - Ciel-2 129W TP 02 Spotbeam 13 changed to Available (H)(Rapid City, SD-CBS)
5118(21) - KNBN [MPEG2 SD] - Ciel-2 129W TP 02 Spotbeam 13 changed to Available (H)(Rapid City, SD-NBC)
5119(7) - KEVN [MPEG2 SD] - Ciel-2 129W TP 02 Spotbeam 13 changed to Available (H)(Rapid City, SD-FOX)
5129(9) - KBHE [MPEG2 SD] - Ciel-2 129W TP 02 Spotbeam 13 changed to Available (H)(Rapid City, SD-PBS)
613 - TVASA [MPEG2 SD] - EchoStar3 61.5W TP 18 ConUS beam changed to hidden from non-subs (A) (H)
653 - SETA [MPEG2 SD] - EchoStar11 110W TP 06 ConUS beam changed to Available
653 - SETA [MPEG2 SD] - EchoStar3 61.5W TP 14 ConUS beam changed to Available
832 - SETA [MPEG2 SD] - EchoStar11 110W TP 06 ConUS beam changed to Available
832 - SETA [MPEG2 SD] - EchoStar3 61.5W TP 14 ConUS beam changed to Available
6581(38) - WLMO [MPEG2 SD] - Ciel-2 129W TP 06 Spotbeam 25 changed to Available (H)
Channel Renames:
9645(99) - LF1 - EchoStar11 110W TP 10 ConUS beam renamed to CAVE (A)
9645(99) - LF1 - EchoStar8 77W TP 29 ConUS beam renamed to CAVE (A)
Channels in the system: 6630
(A) = Available to subscribers
(NA) = Not Available
(H) = Hidden from non-subscribers
HD Local Upgrade
Does anyone know where there I can find a HD locals schedule? I get my locals from the Quad Cities Iowa/Illinois (Davenport, Rock Island, Moline, Bettendorf) Market and they were scheduled initially on a press release scheduled for HD upgrade last fall. It never happened and I was hoping to find out if anyone knew of a updated schedule. :confused:
Same time changed market# from 43 to 42 of
8523 WRLM at 61.5W and 110W.
WRLM is a full-powered television station licensed to Canton, Ohio and serves the Akron-Canton area as part of Cleveland-Akron-Canton, Ohio market. The station is owned by Tri-State Christian Television.
WRLM's tower is located in Brimfield, near Interstate 76.
who-hoo, but CBS is missing.
Nerver mind I found it.
Note to Digi this is CBS out of Lima, OH.
I'll update my tables on it so we get a City/State and Affiliate. In each subcategory of the report the changes are sorted by State then City. This keeps most of the locals together and makes things easier to read when Dish is reusing channel numbers as the markets don't get interleaved this way. Made it a pain to read before! But in your case since I dont have WLMO at all, it falls to the bottom.
But in the weird cases where the FOX in Natchez, MS belongs to the Alexandria, LA market it gets grouped with the Columbus, MS locals in the changes. Can't really help those cases.
Anyone have any info on the locals that were added this week that do not list the city/state and or affiliation? I like to get them updated so when they go available we will know what they are.
All gathered via Wikipedia... reader beware.
KBNT - San Diego, Univision
WLVT - Allentown, PBS
XHAS - Tijuana (San Diego), Telemundo
WVLT - Knoxville, CBS
KIMA - Yakima, WAS, CBS
KMCC - Laughlin, Mega
WLMO - Lima, OH, CBS
Looks like I'm in for a couple new spanish language stations. Too bad I don't speak Spanish.
digi...isnt this MPEG2 8PSK too? I thought the other Marquette, MI locals were
most markets left are ones that are just one or two locals per DMA
If Dish could do significantly viewed, they probably would have much more up
Off top of head, a few markets that NEED sig viewed to be worthwhile
Mankato MN (CBS only..rest from Mpls)
Glendive, MT (CBS only..rest from Denver and Williston, ND)
Lafayette, IN (CBS only...rest from Indy)
Zanesville, OH (NBC only...rest from Columbus)
Alpena, MI (CBS & PBS only)
St Joe, MO (ABC Only..rest from KC)
but with subschannels now its possible to add some like
Parkersburg, WV (NBC main, Fox & My sub)
Presque Isle, ME (CBS, Fox sub) & PBS
D
7/29/2009 2:20pm - Uplink Activity Report - 5 changes
D
8/22/2009 5:09pm - Uplink Activity Report - 31 changes
