8/31/2016 12:54 - Uplink Report - 27 Changes | SatelliteGuys.US
Uplink PC
Uplink Report PC
707
6
SatelliteGuys.US DishNetwork Uplink Report - 8/31/2016 12:54 - 27 Changes
Uplink Comparison Range: 8/31/2016 12:47 - 8/31/2016 12:54 (PST)
MAP Changed:
4491(560) - NBATV [MPEG4 HD] EchoStar14 119W TP 03 Spotbeam B22 map (560) removed (NBA Television)(A)(H)
5001(560) - NBATV [MPEG4 HD] Nimiq5 72.7W TP 06 ConUS map (560) removed (NBA Television)(A)(H)
5001(560) - NBATV [MPEG4 HD] Ciel-2 129W TP 32 ConUS map (560) removed (NBA Television)(A)(H)
5003(561) - NBA [MPEG4 HD] Nimiq5 72.7W TP 08 ConUS map (561) removed (NBA League Pass)(A)(H)
5003(561) - NBA [MPEG4 HD] Ciel-2 129W TP 25 ConUS map (561) removed (NBA League Pass)(A)(H)
5005(562) - NBA [MPEG4 HD] EchoStar14 119W TP 07 ConUS map (562) removed (NBA League Pass)(A)(H)
5005(562) - NBA [MPEG4 HD] Nimiq5 72.7W TP 01 ConUS map (562) removed (NBA League Pass)(A)(H)
5007(563) - NBA [MPEG4 HD] Nimiq5 72.7W TP 30 ConUS map (563) removed (NBA League Pass)(A)(H)
5007(563) - NBA [MPEG4 HD] Ciel-2 129W TP 18 ConUS map (563) removed (NBA League Pass)(A)(H)
5009(564) - NBA [MPEG4 HD] Nimiq5 72.7W TP 10 ConUS map (564) removed (NBA League Pass)(A)(H)
5009(564) - NBA [MPEG4 HD] Ciel-2 129W TP 26 ConUS map (564) removed (NBA League Pass)(A)(H)
5011(565) - NBA [MPEG4 HD] Nimiq5 72.7W TP 08 ConUS map (565) removed (NBA League Pass)(A)(H)
5011(565) - NBA [MPEG4 HD] Ciel-2 129W TP 25 ConUS map (565) removed (NBA League Pass)(A)(H)
5013(566) - NBA [MPEG4 HD] Nimiq5 72.7W TP 10 ConUS map (566) removed (NBA League Pass)(A)(H)
5013(566) - NBA [MPEG4 HD] EchoStar11 110W TP 14 ConUS map (566) removed (NBA League Pass)(A)(H)
5015(567) - NBA [MPEG4 HD] Nimiq5 72.7W TP 01 ConUS map (567) removed (NBA League Pass)(A)(H)
5015(567) - NBA [MPEG4 HD] Ciel-2 129W TP 27 ConUS map (567) removed (NBA League Pass)(A)(H)
5017(568) - NBA [MPEG4 HD] Nimiq5 72.7W TP 08 ConUS map (568) removed (NBA League Pass)(A)(H)
5017(568) - NBA [MPEG4 HD] Ciel-2 129W TP 25 ConUS map (568) removed (NBA League Pass)(A)(H)
5019(569) - NBA [MPEG4 HD] Nimiq5 72.7W TP 01 ConUS map (569) removed (NBA League Pass)(A)(H)
5019(569) - NBA [MPEG4 HD] Ciel-2 129W TP 27 ConUS map (569) removed (NBA League Pass)(A)(H)
5021(570) - NBA [MPEG4 HD] Echostar16 61.5W TP 05 Conus map (570) removed (NBA League Pass)(A)(H)
5021(570) - NBA [MPEG4 HD] Ciel-2 129W TP 26 ConUS map (570) removed (NBA League Pass)(A)(H)
5023(571) - NBA [MPEG4 HD] Nimiq5 72.7W TP 10 ConUS map (571) removed (NBA League Pass)(A)(H)
5023(571) - NBA [MPEG4 HD] Ciel-2 129W TP 26 ConUS map (571) removed (NBA League Pass)(A)(H)
5025(572) - NBA [MPEG4 HD] Nimiq5 72.7W TP 20 ConUS map (572) removed (NBA League Pass)(A)(H)
5025(572) - NBA [MPEG4 HD] Ciel-2 129W TP 26 ConUS map (572) removed (NBA League Pass)(A)(H)
Channels in the system: 9586
(A) = Available to subscribers
(NA) = Not Available
(H) = Hidden from non-subscribers
(FP) = Free Preview
The Format and Layout of the SatelliteGuys Uplink Report is © Copyright 2016 SatelliteGuys.US and may not be republished without written permission from SatelliteGuys.US.
SatelliteGuys Uplink PC Version 1.0.2
© 2016 - All Rights Reserved - SatelliteGuys Incorporated
Yep, I'm getting NBATV on channel 156. League Pass is only good during the NBA season...
And NBATV says (A)(H) which means clearly its available to customers whom subscribe.
It would say (NA) if it wasn't avaliable Juan.
Samsung Galaxy S6 Active
There was a lot more in the uplink not included here that is listed on the other site. It appears the NBA channels were moved to 5002-5061 range where 30 of the channels are SD and 30 of the channels are HD (all the even number channels are SD, odd number channels are HD). My opinion is that NBA league pass is going to have both home/away feeds for each game, sort of like Extra Innings has. The nice thing is if Dish is truly designating 30 SD and 30 HD channels, that is enough channels for each team to have it's home feed on it's own channel. It could be something like Atlanta Hawks home feed being channels 5002 and 5003; Boston Celtics home feed would be 5004/5005; etc. Would be nice so people who buy League Pass could always go to a specific channel for a home team's feed.
Reactions: Tampa8 and pattykay
The nice thing about putting the NBA League Pass SD and HD feeds on separate four-digit channel numbers is that it solves the problem of the receiver defaulting to the SD feed whenever you lose signal on the HD feed. This would be especially annoying in reverse, if the game is only being carried in SD and you lose signal on the SD channel, the receiver would switch to an HD channel showing nothing but the sports slate. This solves both of those problems since the channel numbers are not being duplicated. Hopefully the other sports packages will also get moved to the four-digit channel range.
Looks like my prediction was right. The online program guide has a dedicated channel number for each team, both an HD and an SD channel. Even for teams that Dish doesn't carry the RSN for.
Reactions: pattykay and Tampa8
9/29/2016 10:44 - Uplink Report - 3 Changes
10/11/2016 07:10 - Uplink Report - 9 Changes
