8 bay channel master antenna | SatelliteGuys.US
hdhead
21
Quick question,
If one were to bend channel master's 8 bay antenna (essentially two four bays connected side by side) into more of a wedge shape, would that widen the off axis pickup ability?
hdhead said:
Quick question,
Yes, and reduce the gain to that of the cheaper and smaller 4 bay. Is there a reaason that you wouldn't buy the 4 bay in the first place?
I originally had a four bay up there, but switched to the eight bay and got improved gain, but a more narrow pickup. I traded stronger signal levels for a couple channels and am hoping to get all of the channels. If I turn the antenna 10 degrees, I can pickup the other stations, but lose two others.
FYI, I live in 63070, but am down in a valley so I have to pull my locals from Cape Girardeau MO, Carbondale IL and Padukah KY.
