811 Timers Still Broken? | SatelliteGuys.US
snathanb
2,580
4
DFW
I've had the 811 for a year now, but just bought a DVD recorder.
I set a timer to record an program off an OTA HD channel last night. Since I couldn't find a remote code that would operate my DVD recorder, I set it as an auto-tune event, and set a separate timer on my DVD record.
The DVD recorder kicked off, but it recorded an hour of blank video.
I had turned the 811 off before going to bed. Isn't it supposed to wake itself up and tune to the correct channel?
I know I've read about timer issues and blank video from timers on the 811 in the past, but never had occassion to record, so I haven't kept up with the issue.
If anyone could fill me in on what the current status is, I'd appreciate it.
I'm running version 2.84 on my 811.
tonyp56 said:
I am almost sure that the 811 doesn't fire timers when it is in standby mode, perhaps it should, I don't think it does!
According to the manual, it is supposed to.
I just tried it again and it worked... so I don't know why it didn't fire last night.
Yeah, but according to the manual it is supposed to have unlimited favorites lists. :D I've learned along time ago not to believe anything the manual says!
Glad to hear it worked for you though, to bad it didn't when you needed it to.
i got a gripe about the rate increase!!!
Two Active Satellites - One Service ?
