9/20/2012 5:02am - Uplink Activity Report - 25 changes | SatelliteGuys.US
D
DigiDish Uplink Report
Guest
SatelliteGuys.US DishNetwork Uplink Activity Report - 9/20/2012 5:02am - 25 changes
Uplink Comparison Range: 09/20/2012 04:46A - 09/20/2012 05:01A
Channel Moves:
6130 - KABC [MPEG2 SD] moved from EchoStar11 110W TP 03 ConUS beam to EchoStar5 148W TP 05 ConUS beam (Los Angeles, CA)(NA)
6131 - KCBS [MPEG2 SD] moved from EchoStar11 110W TP 03 ConUS beam to EchoStar5 148W TP 05 ConUS beam (Los Angeles, CA)(NA)
6132 - KNBC [MPEG2 SD] moved from EchoStar11 110W TP 03 ConUS beam to EchoStar5 148W TP 05 ConUS beam (Los Angeles, CA)(NA)
6133 - KTTV [MPEG2 SD] moved from EchoStar11 110W TP 03 ConUS beam to EchoStar5 148W TP 05 ConUS beam (Los Angeles, CA)(NA)
6134 - KMGH [MPEG2 SD] moved from EchoStar11 110W TP 03 ConUS beam to EchoStar5 148W TP 05 ConUS beam (Denver, CO)(NA)
6135 - KCNC [MPEG2 SD] moved from EchoStar11 110W TP 03 ConUS beam to EchoStar5 148W TP 05 ConUS beam (Denver, CO)(NA)
6136 - KUSA [MPEG2 SD] moved from EchoStar11 110W TP 03 ConUS beam to EchoStar5 148W TP 05 ConUS beam (Denver, CO)(NA)
6137 - KDVR [MPEG2 SD] moved from EchoStar11 110W TP 03 ConUS beam to EchoStar5 148W TP 05 ConUS beam (Denver, CO)(NA)
6138 - WLS [MPEG2 SD] moved from EchoStar11 110W TP 03 ConUS beam to EchoStar5 148W TP 05 ConUS beam (Chicago, IL)(NA)
6139 - WBBM [MPEG2 SD] moved from EchoStar11 110W TP 03 ConUS beam to EchoStar5 148W TP 05 ConUS beam (Chicago, IL)(NA)
6140 - WMAQ [MPEG2 SD] moved from EchoStar11 110W TP 03 ConUS beam to EchoStar5 148W TP 05 ConUS beam (Chicago, IL)(NA)
6141 - WFLD [MPEG2 SD] moved from EchoStar11 110W TP 03 ConUS beam to EchoStar5 148W TP 05 ConUS beam (Chicago, IL)(NA)
6146 - WABC [MPEG4 HD] moved from EchoStar11 110W TP 03 ConUS beam to EchoStar5 148W TP 03 ConUS beam (New York, NY)(NA)
6147 - WCBS [MPEG4 HD] moved from EchoStar11 110W TP 03 ConUS beam to EchoStar5 148W TP 03 ConUS beam (New York, NY)(NA)
6148 - WNBC [MPEG4 HD] moved from EchoStar11 110W TP 03 ConUS beam to EchoStar5 148W TP 03 ConUS beam (New York, NY)(NA)
6149 - WNYW [MPEG4 HD] moved from EchoStar11 110W TP 03 ConUS beam to EchoStar5 148W TP 03 ConUS beam (New York, NY)(NA)
6151 - KMGH [MPEG4 HD] moved from EchoStar11 110W TP 03 ConUS beam to EchoStar5 148W TP 01 ConUS beam (Denver, CO)(NA)
6152 - KCNC [MPEG4 HD] moved from EchoStar11 110W TP 03 ConUS beam to EchoStar5 148W TP 01 ConUS beam (Denver, CO)(NA)
6153 - KUSA [MPEG4 HD] moved from EchoStar11 110W TP 03 ConUS beam to EchoStar5 148W TP 01 ConUS beam (Denver, CO)(NA)
6154 - KDVR [MPEG4 HD] moved from EchoStar11 110W TP 03 ConUS beam to EchoStar5 148W TP 01 ConUS beam (Denver, CO)(NA)
6156 - WLS [MPEG4 HD] moved from EchoStar11 110W TP 03 ConUS beam to EchoStar5 148W TP 01 ConUS beam (Chicago, IL)(NA)
6157 - WBBM [MPEG4 HD] moved from EchoStar11 110W TP 03 ConUS beam to EchoStar5 148W TP 01 ConUS beam (Chicago, IL)(NA)
6158 - WMAQ [MPEG4 HD] moved from EchoStar11 110W TP 03 ConUS beam to EchoStar5 148W TP 01 ConUS beam (Chicago, IL)(NA)
6159 - WFLD [MPEG4 HD] moved from EchoStar11 110W TP 03 ConUS beam to EchoStar5 148W TP 01 ConUS beam (Chicago, IL)(NA)
Transponder Changes:
EchoStar11 110W TP 03 ConUS beam changed from 21500 8PSK 2/3 to 20000 QPSK 7/8
Channels in the system: 8674
(A) = Available to subscribers
(NA) = Not Available
(H) = Hidden from non-subscribers
(FP) = Free Preview
The Format and Layout of the SatelliteGuys Uplink Report is © Copyright 2012 SatelliteGuys.US and may not be republished without written permission from SatelliteGuys.US.
The SatelliteGuys Uplink Report is powered by Digiblur Technologies! - DigiDish v12.04.10
© 2012 - All Rights Reserved - SatelliteGuys Incorporated
Even worse 148 now shows up in my satellite list on my 622 after an apparent pushed update a few minutes ago..No way we could get anything on 148 if it were real...way too much clutter
D
9/20/2012 2:47am - Uplink Activity Report - 24 changes
D
9/23/2012 8:02am - Uplink Activity Report - 3 changes
