9/22/2010 3:06am - Uplink Activity Report - 42 changes | SatelliteGuys.US
D
DigiDish Uplink Report
Guest
SatelliteGuys.US DishNetwork Uplink Activity Report - 9/22/2010 3:06am - 42 changes
Uplink Comparison Range: 09/22/2010 02:50A - 09/22/2010 03:05A
Channel Additions:
8810(7) - KOAT [MPEG2 SD] added to EchoStar14 119W TP 02 Spotbeam B8 (Mkt:Albuquerque, NM-Albuquerque, NM-ABC) (A) (H)
8811(13) - KRQE [MPEG2 SD] added to EchoStar14 119W TP 02 Spotbeam B8 (Mkt:Albuquerque, NM-Albuquerque, NM-CBS) (A) (H)
8812(4) - KOB [MPEG2 SD] added to EchoStar14 119W TP 02 Spotbeam B8 (Mkt:Albuquerque, NM-Albuquerque, NM-NBC) (A) (H)
8813(2) - KASA [MPEG2 SD] added to EchoStar14 119W TP 02 Spotbeam B8 (Mkt:Albuquerque, NM-Santa Fe, NM-FOX) (A) (H)
8814(19) - KWBQ [MPEG2 SD] added to EchoStar14 119W TP 02 Spotbeam B8 (Mkt:Albuquerque, NM-Santa Fe, NM-CW) (A) (H)
8815(50) - KASY [MPEG2 SD] added to EchoStar14 119W TP 02 Spotbeam B8 (Mkt:Albuquerque, NM-Albuquerque, NM-CW) (A) (H)
8816(5) - KNME [MPEG2 SD] added to EchoStar14 119W TP 02 Spotbeam B8 (Mkt:Albuquerque, NM-Albuquerque, NM-N/A) (A) (H)
8817(32) - KAZQ [MPEG2 SD] added to EchoStar14 119W TP 02 Spotbeam B8 (Mkt:Albuquerque, NM-Albuquerque, NM-N/A) (A) (H)
8818(41) - KLUZ [MPEG2 SD] added to EchoStar14 119W TP 02 Spotbeam B8 (Mkt:Albuquerque, NM-Albuquerque, NM-UNI) (A) (H)
8819(25) - KTEL [MPEG2 SD] added to EchoStar14 119W TP 02 Spotbeam B8 (Mkt:Albuquerque, NM-Carlsbad, NM-TEL) (A) (H)
8822(11) - KCHF [MPEG2 SD] added to EchoStar14 119W TP 02 Spotbeam B8 (Mkt:Albuquerque, NM-Santa Fe, NM-N/A) (A) (H)
8823(27) - KRPV [MPEG2 SD] added to EchoStar14 119W TP 02 Spotbeam B8 (Mkt:Albuquerque, NM-Roswell, NM-N/A) (A) (H)
8824(14) - KTFQ [MPEG2 SD] added to EchoStar14 119W TP 02 Spotbeam B8 (Mkt:Albuquerque, NM-Albuquerque, NM-TEL) (A) (H)
Channel Moves:
7356 - WEIQ [MPEG2 SD] moved from EchoStar10 110W TP 31 Spotbeam 11 to EchoStar10 110W TP 12 Spotbeam 07 (Mkt:Mobile, AL-Mobile, AL-PBS) (A) (H)
8428 - KYMA2 [MPEG2 SD] moved from EchoStar10 110W TP 31 Spotbeam 39 to EchoStar10 110W TP 27 Spotbeam 39 (Mkt:Yuma, AZ-Yuma, AZ-NBC) (A) (H)
9326 - KCWQ [MPEG2 SD] moved from EchoStar10 110W TP 31 Spotbeam 39 to EchoStar14 119W TP 01 Spotbeam A13 (Mkt:Palm Springs, CA-Palm Springs, CA-CW) (A) (H)
9327 - KUNA [MPEG2 SD] moved from EchoStar10 110W TP 31 Spotbeam 39 to EchoStar14 119W TP 01 Spotbeam B3 (Mkt:Palm Springs, CA-Indio, CA-TEL) (A) (H)
8200 - KMGH [MPEG2 SD] moved from EchoStar11 110W TP 22 ConUS beam to EchoStar10 110W TP 12 Spotbeam 30 (Mkt:Denver, CO-Denver, CO-ABC) (A) (H)
8201 - KCNC [MPEG2 SD] moved from EchoStar11 110W TP 22 ConUS beam to EchoStar10 110W TP 12 Spotbeam 30 (Mkt:Denver, CO-Denver, CO-CBS) (A) (H)
8202 - KUSA [MPEG2 SD] moved from EchoStar11 110W TP 22 ConUS beam to EchoStar10 110W TP 12 Spotbeam 30 (Mkt:Denver, CO-Denver, CO-NBC) (A) (H)
8203 - KDVR [MPEG2 SD] moved from EchoStar11 110W TP 22 ConUS beam to EchoStar10 110W TP 12 Spotbeam 30 (Mkt:Denver, CO-Denver, CO-FOX) (A) (H)
5116 - KOTA [MPEG2 SD] moved from Ciel-2 129W TP 02 Spotbeam 13 to EchoStar14 119W TP 03 Spotbeam B7 (Mkt:Rapid City, SD-Rapid City, SD-ABC) (A) (H)
5117 - KCLO [MPEG2 SD] moved from Ciel-2 129W TP 02 Spotbeam 13 to EchoStar14 119W TP 03 Spotbeam B7 (Mkt:Rapid City, SD-Rapid City, SD-CBS) (A) (H)
5118 - KNBN [MPEG2 SD] moved from Ciel-2 129W TP 02 Spotbeam 13 to EchoStar14 119W TP 03 Spotbeam B7 (Mkt:Rapid City, SD-Rapid City, SD-NBC) (A) (H)
5119 - KEVN [MPEG2 SD] moved from Ciel-2 129W TP 02 Spotbeam 13 to EchoStar14 119W TP 03 Spotbeam B7 (Mkt:Rapid City, SD-Rapid City, SD-FOX) (A) (H)
5129 - KBHE [MPEG2 SD] moved from Ciel-2 129W TP 02 Spotbeam 13 to EchoStar14 119W TP 03 Spotbeam B7 (Mkt:Rapid City, SD-Rapid City, SD-PBS) (A) (H)
4816 - TMP46 [MPEG4 HD] moved from EchoStar14 119W TP 03 Spotbeam B7 to Echostar15 61.5W TP 23 ConUS beam (NA)
4820 - TMP50 [MPEG4 HD] moved from EchoStar14 119W TP 03 Spotbeam B7 to Echostar15 61.5W TP 23 ConUS beam (NA)
4825 - TMP26 [MPEG4 SD] moved from EchoStar14 119W TP 03 Spotbeam B7 to Echostar15 61.5W TP 23 ConUS beam (NA)
4826 - TMP56 [MPEG2 SD] moved from EchoStar14 119W TP 03 Spotbeam B7 to Echostar15 61.5W TP 23 ConUS beam (NA)
4827 - TMP57 [MPEG4 HD] moved from EchoStar14 119W TP 03 Spotbeam B7 to Echostar15 61.5W TP 23 ConUS beam (NA)
4835 - TMP69 [MPEG4 HD] moved from EchoStar14 119W TP 03 Spotbeam B7 to Echostar15 61.5W TP 23 ConUS beam (NA)
4836 - TMP66 [MPEG4 HD] moved from EchoStar14 119W TP 03 Spotbeam B7 to Echostar15 61.5W TP 23 ConUS beam (NA)
4837 - TMP67 [MPEG4 HD] moved from EchoStar14 119W TP 03 Spotbeam B7 to Echostar15 61.5W TP 23 ConUS beam (NA)
4838 - TMP68 [MPEG2 SD] moved from EchoStar14 119W TP 03 Spotbeam B7 to Echostar15 61.5W TP 23 ConUS beam (NA)
4839 - TMP71 [MPEG2 SD] moved from EchoStar14 119W TP 03 Spotbeam B7 to Echostar15 61.5W TP 23 ConUS beam (NA)
4840 - TMP72 [MPEG2 SD] moved from EchoStar14 119W TP 03 Spotbeam B7 to Echostar15 61.5W TP 23 ConUS beam (NA)
6870 - UP29 [MPEG4 HD] moved from EchoStar14 119W TP 03 Spotbeam B7 to Echostar15 61.5W TP 23 ConUS beam (Virtual Channel) (NA)
Transponder Changes:
EchoStar10 110W TP 04 Spotbeam 36 changed from 20000 QPSK 5/6 to 20000 QPSK 3/4
EchoStar10 110W TP 31 Spotbeam 39 changed from 20000 QPSK 5/6 to 20000 QPSK 1/2
EchoStar14 119W TP 03 Spotbeam B7 changed from 21500 8PSK 2/3 to 20000 QPSK 7/8
EchoStar14 119W TP 02 Spotbeam B8 changed from 21500 8PSK 2/3 to 20000 QPSK 7/8
Channels in the system: 7602
(A) = Available to subscribers
(NA) = Not Available
(H) = Hidden from non-subscribers
(FP) = Free Preview
The Format and Layout of the SatelliteGuys Uplink Report is © Copyright 2010 SatelliteGuys.US and may not be republished without written permission from SatelliteGuys.US.
The SatelliteGuys Uplink Report is powered by Digiblur Technologies! - DigiDish v10.08.05
© 2010 - All Rights Reserved - SatelliteGuys Incorporated
whats the temps for and new hd coming?thank you for any replies:)
TSReader shows the following on Echostar 15 Transponder 23:
TMP 46 TNT HD
TMP 50 Cartoon Network HD
TMP 26 Not in stream
TMP 56 Not in stream
TMP 57 LMN HD
TMP 69 MSNBC HD
TMP 66 Fox News HD
TMP 67 CNN HD
TMP 68 Not in stream
TMP 71 Not in stream
TMP 72 Not in stream
It doesn't get much older for HD than TNT HD... ;)
We Want More Old HD !!
would be a good slogan in keeping with 2010's theme of demanding the opposite of what would help us...
TMP 46 TNT HD
TMP 57 LMN HD
TMP 69 MSNBC HD
TMP 66 Fox News HD
TMP 67 CNN HD
thank you for your help and reply:)what is not in stream a channel maybe coming soon?
whats weird is neither spotbeam (old or new) according to the maps cover the whole DMA. The RC DMA is pretty much the western part of SD
D
9/22/2010 4:53am - Uplink Activity Report - 2 changes
D
9/22/2010 5:07pm - Uplink Activity Report - 45 changes
