Hello i got a new 9200 for xmas and ran into some install problems. I got the dish setup without a problem with the skew setup to 98. but i do not get anything on the 82 sat my 91 sat is at 85%. Question one should the two lnb be the same or is there some different between the two i should know. Next is all the HD channel on the 82 sat. Third does anyone have the dish allignment numbers for Oklahoma. and last but not least in the box it say just to check the signal on 91 tp 11 to see if over 70 then let the rcvr download something from bev(will this allow me to see the 82 sat then or what) Any and all help is a plus and thank you
