i just got a 922 off ebay how is the best way to check it out.i have it hooked up on G1 And getting cspan
Make sure you have it set to "C-Band LNBF" in the setup menu. Then it will switch polarity on it's own.I Cannot Get to switch polarity.i tried it on standard and Rotate 90 Degree can hook it back to my diamond receiver get it on the other polarity And it will work fine on that polarity I"m switching between G1 and C3 till i get something figured out.
One Other Thing This Unit Still Has A Strazs Subscribed On It .Any To Tell When It Runs Out Are Who It Is With Thanks.
Limited time offer
