A/B Switch | SatelliteGuys.US
A/B Switch
Sonnn
3
Wisconsin
Is it possible to use a A/B switch when you have 2 dishes ( Western & Eastern) to switch between the dishes? I understand that if possible you would have to run a check switch if you would switch between them correct?
Any input would be appreciated
Biggest concern would be does the switch pass the frequencies that are coming down the pipe from the Dish LNB?
Dish stacks frequencies, especially on the H3, so that might be a real problem.
Reactions: charlesrshell
Been using a A-B Switch from toggling between the Winegard Trav'ler on the roof and a ground tripod dish for 13 years. Look for a high quality switch.
Contemporary Research RF-AB
RF A-B Switch, self-terminating, closure controlled 2.5 Ghz
This one works great...
Thanks for your input
DISH Sues Univision
Live Dish channels on Delta flights??!
