A couple DVR questions | SatelliteGuys.US
nyvram
168
1. I still have comcast $11/mo 'basic cable' which has locals in HD and some other junk. Can the tuner in the 722 tune those in under the "OTA" option if I hook up my coaxial cable to the back of the DVR? I am a little hesitant to do that unless I know its not going to blow anything up. Is there an ATSC/QAM tuner for that purpose or strictly an ATSC? What do I need to do to 'tell' my DVR its an actual cable signal?
2. Can someone direct me to a 'power user' guide for tricks/tips on maximizing the DVR for finding shows? I know there are some boolean tricks but its a bit daunting to have to relearn a DVR so I'm hoping for a FAQ or something that shows off the coolest tricks with the DVR that I might not know about.
Thanks!
PS Claude, thanks for the call yesterday. Your company's reputation continues to grow in my opinion and I wouldn't dare recommend anyone get DISH without using you to 'dodge the minefield' of programming & install options. Consider this a 5-star review! :up
Free E* for a Year from Local Phone Co.
$55 500GB drive..is ok to post this stuff on here?
