I'm excited about Voom... thinking about giving it a try. I've never had satellite before so I've got some questions.
1. I currently live in an Apartment Complex and would like to use the existing cable lines if possible. I would also like to keep my cable internet, which is a priority for me since dsl is not available. Is it possible to run ota and satellite to three rooms, plus cable internet to one of them all through the existing cable lines?
-If not, the only rule about installing satellite here is that holes can only be drilled inside my patio and apartment. Basically, no holes on the outside wall of the building.
2. I live in Albuquerque, NM and am not sure if I will have line of sight to the satellite. It seems like it's gonna be close. I am not worried so much about ota. I picked up all but one my locals with a cheap indoor antenna and they're all in the same direction on the top of a mountain. Is there a way to test my line of sight though before cancelling cable to make sure Voom will work for me? I found the trajectory file here, but its a windows executable.
3. Is Voom as good as it sounds? Comcast here is awful. Only locals are ABC and Fox in hd and it seems only one at a time works. Even OTA is a step up for me.
Thanks,
Nathan
Thanks,
Nathan
