A little confused | SatelliteGuys.US
A little confused
Yes, it will definately work. Just be careful which 2 ports you connect to the 721 from the SW64. The 721 manual shows you the two correct wiring options that can be used with an SW64 and the 721.
- Paul
921 Price Drop- $899?
? about hd package
