A newbe needs help on recording to VHS from 942 | SatelliteGuys.US
Neo2006
8
Can anyone tell me how to record to a VHS from my 942? I called Dish tech and they did not know how.:confused:
General, High-Level overview of what to do (the devil is in the details - single/dual mode, particular VCR options, etc.)
- Connect the composite video & audio outputs of the 942 (yellow, red, white) to the inputs on the VCR.
- Use whatever menu/selections you have on the VCR to select these inputs - usually some sort of "line input" menu option
- Press "Record" button on the VCR - the VCR will record whatever is being output from the 942
- If you are wanting to record to VCR a previously recorded DVR event, play that event.
RV use for a Dish dummy
Dish Network Sat. Map
