Hi Guys
I took down my 8 foot dish and put an extension on the pole and put up a 6 foot solid dish. I am now working about 15 feet above the ground which makes adjustments a challenge.
Here is my problem: The pole is level all around, I have set the declination and elevation and triple checked these settings. I have swung the dish south and have found my south satellite, but I am only receiving a 50 % signal and it doesn't improve if I push up or pull down on the dish. When I run the arc I am only receiving the top 4 or 5 satellites and them the bottom sats at both ends.
Any of the sats I am getting only giving me a signal of around 50 to 60 %. If I center the dish over the mount and look across the dish it should look like the bottom of a pan but it doesn't, I can see about 3 inches of dish on the left side all the way up.
I have pushed and pulled the dish on the extreme east and west and then made the adjustments, and every time I try to correct I loose everything.
I'm wondering if the dish shape is the problem and it doesn't matter what I do I will never get this dish aligned.
Any thoughts would be appreciated.
