AAD local phone number? | SatelliteGuys.US
barfo
63
I would rather not phone the 800 number to order distants. Does anyone know, or know how I can get, the AAD distant nets ordering department using a non 800 number? TIA.
I worried about the 800 number but they do not compare area code of where you are calling from against the area code of your service address. I do not know if that is your concern. I have no clue of a local number, unless they moved the call center is in Indianpolis IN. Which is 317 area code maybe try 411 in Indy.
Not so much paranoid, just concerned that a call originating from my vacation home outside the US might not get through, and if it did it might confuse the CSR if they saw the originating number on their call display. P.S. Caller ID blocking does not work for 800 numbers.
HD in west Texas
Trouble with eastern arc
