ABC News One Live yet on 91W? | SatelliteGuys.US
There are now 4 ABC feed channels on 91w, 12011 V 13333. Two are SD -480i and two are HD - 720p.
I'll try it this afternoon, my equipment only captures simple DVB-S channels.
Thank you very much!
The transponder and the two SD channels scan in on my Pansat 3500SD so you should be able to get them. You might need to tweak your dish (manually enter in the transponder and use it to peak).
Ready... first I got the CCTV channels and then.. the 91 W. Good! (Although this morning there was no signal on channel 2).
Newbie question
