AC to DC Power Transformers | SatelliteGuys.US
Not open for further replies.
joeh
104
Louisville, KY Aera
AC to DC Power adapter
Hey guys,
I have a really stupid question here. I have a electronic device here, that needs a power adapter/transformer of 13.8V @ 500mA. I have a power adapter that is 13.8V but it is at 1A. Will it be ok to use this even though it only needs 500mA.
man it's been a long time, somebody correct me if i'm wrong here.
The amperage rating on the transformer is the maximum it can safely and reliably provide, so yes, a device requiring less should be ok. The actual amount of current drawn is determined by the device itself.
thanks, that is what I was thinking but wanted to post here and make sure that it was correct, before i plugged it in and blew it up.
Its fine but if its DC mind the correct polarity.... 500a is a half amp
if you ask me they should standardize on just a few ratings and let the device obtain the correct voltage
yep, you are correct 500 mA is 1/2 an amp (1 mA is 1 one thousandth of an amp) and current is drawn, not forced, if you want to protect your device, install a 1/2 amp fuse in the positive lead of the load side of the transformer.
Cage Brings 'Dresden Files' to Sci Fi
Need Help 2 Make U $$$
