Accessing contents of the EHD | SatelliteGuys.US
PirateTodd
84
5
Ohio
My EHD keeps telling me I need to reformat in order to use it, even though it's worked for years. I'm afraid I'll lose all my recordings. Dish is trying to help me with it, but I keep getting the same reformat message.
Does anyone know if there is a way that I can atleast look up what i have stored on the drive so I know what shows I might be losing? I never backed it up on another computer, but I didn't know if I plugged it in to another source if it would show me the content stored on it. Atleast I will know what I had stored on there if I'm able to do that.
I'm afraid you are out of luck there. I wish you luck in resolving the issue. Is this the only EHD you are using. Have you asked Dish for a re-hit? Also, chances are your drive is corrupted and can't be recognized as an "in service" device.
That sucks....they tried a re-hit and it didn't work. I don't know how it would have been corrupted. I've had it hooked up to the Hopper for years now. This issue came out of nowhere.
Don't give up yet if you can afford to just set it aside. Wait for your next update and then try it again....
That's my plan for now. I was hoping worst case scenario I could see what shows I had on there if in fact I can't get it to work anymore.
Joey 2 Firmware upgrade to U270
Can I copy the recordings directly off the internal drive?
