Here is my current plan for the room I have now.
Gik Acoustics 242 panels, 3 pack.
242 Acoustic Panel Broadband : GIK Acoustics
Here is a shot of it on optional stand, of course mine will be wall mounted:
I do not have a shot of my seating, but using this image you can imagine it. Exact same as the wall behind the display, except longer. Very tall as well. We have one chair, and a 3 person couch that may be 3" off that wall, with nothing on the wall now. Im sure we are getting a lot of reflections.
My plan, using this image as an idea, is 3 panels of some color. One would be mounted vertically behind my chair, and 2 more would be centered behind the couch.
professionally constructed with a rigid core and built-in air gap
easy wall and ceiling installation using wire integrated in the back like a picture frame
free standing options available using brackets or metal stands
employs ECOSE technology
standard size: 24" x 48" x 3.5"
weight: 9 lbs (each)
can be custom sized to fit your specifications
available in 9 standard GIK Acoustics fabric colors
additional Guilford of Maine fabric choices available
