I am trying to setup a mini bud on my channel master 1.2 dish. As per my understanding I have to tune ku band first and then replace the ku lnb with C lnb. Can somebody confirm what TPs are active on this bird
Nothing except for wild feeds. Tons of scambled channels if you have a DC11 receiver.I am trying to setup a mini bud on my channel master 1.2 dish. As per my understanding I have to tune ku band first and then replace the ku lnb with C lnb. Can somebody confirm what TPs are active on this bird
Unfortunately I do not have a DC2 receiver handy. I might just have to try to find the signal with C band lnbf.Nothing except for wild feeds. Tons of scambled channels if you have a DC11 receiver.
Sent from my LG-M153 using the SatelliteGuys app!
Yes i have the Dr. HD 1000S+Try 4100 V. If you don't find anything,
Try 11940 V on 103w on a ku lnb. Then install the c band lnb and move west a few degrees.
Do you have a satmeter?
I might be able to find a used shaw receiver on kijiji for cheap but i would rather use that money on something else and go through the harder route of tuning 107 with C band lnbAre there still FTA channels available on 107 if you have a deactivated Shaw box?
Limited time offer
