I know this was post before but can't find it. but what do I need to type in tp for cw 3720 H
tp 1 vid 101 and audio 102? or ??
thanks,
Fire1000
thanks,
Fire1000
Thanks JIm for posting that. I can do it on the Coolsats easily but the Traxis I forget how that works![]()
Very easy with the Traxis 3500.
1. Scan in 3 C Band channels on G17. There are plenty of them and it doesn't matter which ones you use. Remember what the FR and SR to these channels are
2. Hit OK and bring up the channel list and hit the first channel.
3. Hit 5, enter for password 0000 (4 zeros), then hit 4, edit.
4. Arrow up to the top line and enter the channel name you want, in this case CW East, arrow down to the next line and enter your Video PID which is 101, next line Audio PID which is 102, the the PRC PID whichis 101. (Usually the VPID and PCR are the same)
5. Arrow down at hit save, then exit.
6. Exit out of the channel and list at hit the menu button.
7. Go to the CBand FR list and find the FR and SR of the channel you scanned in step 1. Change the FR to 3720 and the SR to 26700, hit exit and yes.
8. Go to the channel list and hit the channel you nameds CW East and it's there.
Do this two more time to the other channels using the PIDs that I entered in the previous post and you will have all 3 CW channels.
This sounds more complicated than it is. Once you do it a few times you will see how easy it is.
I did this from memory so if you have any promlems feel free to PM me and we will solve them.
Limited time offer
