Add on LNBF for big dish | SatelliteGuys.US
RLDSL
49
4
Is it possible to cheap out and just take a small dish KU LNBF and clamp it onto the framework of my BUD ( and yes, it has the small holes ) so I can pickup the KU band , or do I HAVE to fork out the cash for a double feed horn and new LNB setup?
Thanks-----------Robert
Has been done, I just saw a picture of one yesterday, I would give it a try and tell US how you get on, if I see the picture I will post it here! Good Luck!
Next big question is, should I get a standars one and mount it right in the center next to the c band LNBF or should I try one for an offset dish and mount it half way down one of the braces?
Also would a universal LNBF gain me anything ( or cause more problems )?
And just out of curiosity, would a direct tv DSS type LNBF work , or are those things only good for their intended use ( I know where there's a used one cheap...$10 with the reciever and dish, although I have no Idea what I'd do with the rest of that stuff ) ?
Thanks--------Robert
The picture I seen yesterday had the DirecTV LNB strapped near the C band lnb pointing towards the focal point of the dish, I would go for the $10 LNB you seen and try a few experiments, still trying to find that picture I seen!
It is my understanding that it should be mounted to the left or right of the C-Band LNBF. Since the elevation is a fixed value, putting the Ku lnb down on the arm for an offset would not work. The whole dish would have to be dropped in elevation and then you would lose your C-band.
Its easier to adjust left/right since that is the axis your BUD moves on anyway.
That makes sense. It should be pretty east to attach the thing.
----------Robert
Thanks for the picture.
I guess my idea of making a bracket out of plumbers tape will look downright custom next to that black elecktric tape :-)
Off to the perminant yard sale tomorrow to see if those folks still have the used LNBF and other stuff.
------Robert
Looking for FTA FAQ links.
Totally Frustrated
