Add SD receiver | SatelliteGuys.US
Add SD receiver
ryanjk66
2
Hi
I'm new to this forum and need some help
I believe I have the HR20 receiver (HD DVR bought in July) with the 5 LNB slimline dish. I currently have only one HD TV hooked up and would like to add a SD TV. I know DirecTV will now charge me for another receiver because I am no longer a new customer so I'm looking into buying a used one. What do I need to do to hook up a standard receiver to my 5 LNB dish without permanently affecting my HR20.
Ryan
You will need to run an additional line from the dish to the new room. Try talking to customer service about the extra receiver. They might work a deal with you to run the extra line and supply the receiver. Doesn't hurt to try.
Little Rock ABC
D11 Signal Problems
