No selection available to add SatGuys to my home screen from Chrome browser in my Android cell phone. All other web sites has Add to Home screen available. SatGuys web site use to have the capability but no longer. Any one have a clue why not?
It appears that the mobile version of the site turns off the Chrome status bar (and thusly Chrome's own Hamburger Menu) and that's where Chrome's "add to home screen" option was. If you check your running apps, you'll find that the site runs in a new window. I'm not sure how to turn on the status bar once it has been turned off.SatGuys web site use to have the capability but no longer.
Thanks Scott. I did have a SatGuys icon on my home page but decided to delete it and make a new one to see if it would help the slow to open issue. Sometimes it was taking the site up to 10 seconds to open when I selected the icon. Since the Add to Home page selection isn't there anymore I installed the SatGuys app. It takes me three clicks now instead of one to get to the Watched Threads page that I like to open with.I don't have an Android device to test, but if I had to guess this started happening around the time we update Xenforo and upgraded our styles for the new version of Xenforo.
I will look tomorrow and see what I can find, and will load up blue stacks on a PC so I can test from Android.
Happy 4th!
Any luck Scott Greczkowski figuring out the Add to Home screen issue?I don't have an Android device to test, but if I had to guess this started happening around the time we update Xenforo and upgraded our styles for the new version of Xenforo.
Happy 4th!
Yep, I guess bookmark is what I want. I did have a bookmark on my home screen that took me straight to my watched threads. Now I have to use the SatGuys app on my home screen and it takes more steps. Thanks for checking.Add to Home Screen works for me in Bluestacks. I went to the home page in Google Chrome in Android, then clicked on the three dots to the right of the URL board and clicked on add to Home Screen.
It added a SatelliteGuys! app to the home screen.
I do notice that is is now a PWA (Progressive Web App) and not just a bookmark on the home screen. This is something new in Xenforo. And there are no settings for it other then text direction (left to right or right to left) and setting the logo icon. It (android) no longer saves it as a book mark to your screen like it use to since PWA is built into the forum software.
I will keep looking around and see if there is a way to put a bookmark on your Home Screen. Which is what I believe you are trying to do.
ThanksThis may work... trying to figure out how to do it on Bluestacks on my Mac.
OK, I will keep working with this. I can't figure it out yet but will keep trying.Add Chrome Bookmarks on Android Home Screen - iFixScreens
How do I add Chrome bookmarks to my Android home screen? — How do I save a bookmark to my home screen Android?ifixscreens.com
This one worked for me. Using the Bookmark widget.
Limited time offer
